HD radio reception
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobbyds1, Aug 11, 2023.
  1. Aug 11, 2023 at 10:30 AM
    bobbyds1
    bobbyds1 [OP] Well-Known Member
    Bob
    2013 tacoma base
    Hi I just installed a Kenwood DMX809 Head unit that has HD radio problem i seem to have is picking up stations when it scan it skip over stations that my other vehicle receives. has any one have this problem when changing head units. did you have to change your stock fender mount antenna or did you have to add a antenna signal booster.
    Any help and comments would be greatly appreciated.
  2. Aug 11, 2023 at 11:47 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Sometimes HD stations in certain areas don’t come through . Try shutting the HD part off ( I don’t know your Kenwood unit or if you can ) then in regular stereo see if they come in easier
  3. Aug 11, 2023 at 12:03 PM
    Cyberfool
    Cyberfool Well-Known Member
    Jack
    Balto MD
    You need a strong signal to get HD radio. Truck Guy is correct, turn HD off.
    Also, make sure your antenna connection is fully seated.
  4. Aug 11, 2023 at 12:09 PM
    bobbyds1
    Bob
    2013 tacoma base
    In my are there are a lot of hd stations thats why i purchased this head unit Im just wondering if i need a better antenna or a signal booster
  5. Aug 11, 2023 at 3:51 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Did ya plug in the antenna
