BAMF HD Shackle hangers
Discussion in 'Bay Area Metal Fabrication' started by JLee, Jun 13, 2017.
  1. Dec 14, 2017 at 12:29 PM
    #101
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    he answered that with the photo above...that's what i was thinking but the ATO is a different design
    ragincajun35[QUOTED] likes this.
  2. Dec 14, 2017 at 12:31 PM
    #102
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    grind down the center gusset maybe? or see if someone local wants to trade a HD for a OEM? then order a BAMF when they're ready
  3. Dec 14, 2017 at 12:35 PM
    #103
    ragincajun35
    ragincajun35 Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    Yea the ATO doesnt have an orientation that i can tell. It has that center gusset that works fine with the shackle flip kit but when you invert them (stock setup) the center gusset is hitting the leaf spring. Im scrambling to try and get my truck put back together. Not sure what im going to do yet
  4. Dec 14, 2017 at 12:38 PM
    #104
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    if you can't modify the ATO or find an OEM...is there a junkyard that has a 05+ tacoma or an Cherokee XJ (83-01) that you can get a set of shackles off?
  5. Dec 14, 2017 at 12:38 PM
    #105
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    I don't see any reason that leaf can't be trimmed a bit until it clears, I would just take a cut off wheel to it and call it a day
  6. Dec 14, 2017 at 12:38 PM
    #106
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Perhaps this is a good option. Ill look. But ill still have to drill out the factory shackles from what it looks like
  7. Dec 14, 2017 at 12:43 PM
    #107
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's very simple to drill the factory shackles. It's a split sleeve in the bushing that fits the 9/16th bolt to the center they are just misaligned ever so slightly so you have to drill it. And the other side is just 10 gauge stamped steel.
  8. Dec 14, 2017 at 12:45 PM
    #108
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Thats good because going from 1/2" to 9/16" with a drill and a bit didnt go so well last night... need a drill press. Ill try and find some factory shackles.
  9. Dec 14, 2017 at 12:46 PM
    #109
    JLee
    Jerry
    Benicia, CA
    Yeah factory are pretty much 9/16th that's why we went with that over 1/2".
  10. Dec 14, 2017 at 2:21 PM
    #110
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Another observation... the ends of the Dakar springs seem to be different than others I've seen (deaver, all pro, etc). The ends of the main leaf goes straight into the bend. Also the second and third leafs go much further back. Sorry for the crude drawing. For factory shackles this doesn't seem to be a problem but just wanted to point that out.
    Also I got my hands on a set of factory shackles. Hopefully have everything buttoned up tonight. I'd like to place an order for your HD shackles when you start putting those together @JLee
    bsp_taco and NYCO like this.
  11. Dec 14, 2017 at 2:28 PM
    #111
    JLee
    Jerry
    Benicia, CA
    They shouldn't be a problem on ours as well they wont have a gusset in the center like the ATO. It will be more like stock but .250" plate.
    tacoma16 likes this.
  12. Dec 14, 2017 at 2:38 PM
    #112
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Some small additions:
    Make sure to use anti-seize on the 4 bolts that go through the bushing sleeves.
    Deaver uses a 9/16" sleeve and can accept a 9/16" bolt or the factory M13 bolt.
    Dakar and OEM leaf packs use a M13 sleeve and a 9/16 bolt will not fit. If you have dakars or OEM, just use the stock bolts you already have and throw the spare 9/16" hardware in your box-o-shit.
    If you have ATO shackles
    ATO shackles use 1/2" hardware and sleeves. The sleeves are plenty thick. All you need to do is drill out the sleeve to 9/16" to fit the AT shackle into the BAMF hanger with the 9/16" hardware. Don't use shitty drill bits for this process. Make sure you have a quality bit and use cutting fluid or diff oil to keep the drill bit happy. If it gets hot, let it cool down so you don't ruin the drill bit.
    As for the opposite side of the ATO shackle, again this will depend on your leaf pack. Stock packs or Dakar, just use the factory M13 hardware and don't worry about the included 9/16" hardware. For Deaver, you have your option to use the factory M13 hardware, or drill out the holes on the ends of the shackle to 9/16" and use the included 9/16" hardware.
    Deavers with ATO and BAMF:
    Sorry I took this photo with a potato
  13. Dec 14, 2017 at 4:56 PM
    #113
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    @JLee this shit is doesn't work. I need a bigger rock on my property.
  14. Dec 15, 2017 at 2:00 PM
    #114
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    @JLee is there a reason to use a non-oem shackle either these?
  15. Dec 15, 2017 at 2:05 PM
    #115
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Aftermarket gets rid of the stupid tension bushing that's in the stock shackle.
    Arcticelf[QUOTED] likes this.
  16. Dec 15, 2017 at 2:06 PM
    #116
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    OEM is non-greaseable. the BAMF and other aftermarket are greaseable
    and +45 EAF points
  17. Dec 15, 2017 at 2:09 PM
    #117
    Arcticelf
    Gladiator
    Are the bamf ones for sale yet?
    ragincajun35 likes this.
  18. Dec 15, 2017 at 2:29 PM
    #118
    JLee
    Jerry
    Benicia, CA
    You can order them with a hanger kit that will be shipping in January. but not as a stand alone item.
    Wagsbro likes this.
  19. Dec 16, 2017 at 5:35 AM
    #119
    Arcticelf
    Gladiator
    I've got a pending order for a hanger, with cross-member. Any chance of adding shackles to that?
  20. Dec 16, 2017 at 6:50 AM
    #120
    JLee
    Jerry
    Benicia, CA
    Not a problem you will have to reply to the email confirmation you received when placing the order.
