HD Snowsport on 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by usmc0311, Jan 4, 2013.
  1. Jan 4, 2013 at 12:14 PM
    usmc0311
    usmc0311 [OP] Well-Known Member
    2011 Tacoma dble cab long bed
    nerf bars and bug deflector
    Snowsport plow on 2011 Tacoma, plow frame slides into front hitch. Living in New England I can tell you this little plow can move some snow and ill take it over shoveling any day
  2. Jan 4, 2013 at 4:48 PM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    I've always wondered how well those work without being able to lift. Were you able to do this last storm all at once, or in a couple of times to keep up with it?
  3. Jan 5, 2013 at 3:58 AM
    usmc0311
    Just once, works really well
  4. Jan 5, 2013 at 4:00 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    looks good. another member has a plow on his truck.
  5. Jan 5, 2013 at 8:03 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    I do not...understand how this works.
  6. Jan 6, 2013 at 8:31 AM
    usmc0311
  7. Jan 6, 2013 at 8:38 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I like the idea but a buddy has one on his Honda and it is still like 1500 bucks. I will stick with my snow blower
  8. Jan 6, 2013 at 1:56 PM
    RickG
    Southern NH
    I like it too. Over the years the snow blower has lost a lot of it's initial appeal... as has winter in general.
    OP, got any pics of how the front hitch bolts up?
  9. Jan 6, 2013 at 2:03 PM
    pra4sno
    Good stuff! I like it.
    Always had trouble with snow blowers. Gummed up fuel, sheer pins in the auger snapping off, clogs, electric starter shorting out. Makes something like this a bit more interesting.
    The snowblower does give more access to sidewalks, and smaller driveways though. Always a trade off.
  10. Jan 7, 2013 at 4:04 AM
    usmc0311
    It is expensive brand new however i found mine on craigslist for 800. The front hitch was about 120. The hitch was very easy bolt on installation into factory holes. I do still have my snowblower for my walk way and sidewalk.
  11. Jan 7, 2013 at 5:51 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Try using Startron fuel enzyme in your gas, it should keep it from doing anything to the carbs. I've been using it for a while now in my snow blower, lawn mower, chain saw and motorcycle and it seems to work really well.
    I've got a snow blower that plugs into the wall for it's electric start with a pull start backup. It usually starts second pull but the wall outlet thing is nice just in case :D
  12. Feb 15, 2013 at 9:49 AM
    carogabee
    carogabee New Member
    Jerry
    NYS Adirondacks
    I have a question regarding my plow lights. on 11/11/11 i had a Snowdogg md68 installed on my 2011 tacoma. The plow works great...little hard sometimes putting it on, here is the problem. When I disconnect the plow I find that the Passanger side light of my truck not working. I replaced the bulbs ( Drivers and passanger side)and find that i have the same problem....High beams work on both sides. Took it to my local dealer/installer and he felt it was the pig tail infront of passenger side light that came with plow, disconnected the pig tail, installed the factor light plug into pass light and headlight came on. Told me he was going to order new pigtail and did so....long story short , new pigtail not the problem and still not working . when i connect the plow to truck...plow lights work and truck lights go off. Any Ideas. Jerry
