Head bolt torque spec
Discussion in '4 Cylinder' started by Walt Cakebread, Mar 1, 2010.
  1. Mar 1, 2010 at 6:24 PM
    Walt Cakebread
    Walt Cakebread [OP] New Member
    Walt
    Nebraska
    97 Tacoma
    I'm replacing the head gasket on a 2.7 Ci Taco. Using new head bolts. My manual doesn't list torque values ( turn bolt 90 degrees ) I prefer to tighten the bolts to a specific value. Can someone tell me the proper final specification?
    Thank You
  2. Mar 1, 2010 at 7:55 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I think this one might have what you need
  3. Mar 1, 2010 at 7:58 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    Make sure they are not torque to yield bolts. If they are make sure you replace them.
  4. Mar 1, 2010 at 7:58 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    29ft lbs in order
    turn 90deg in order
    turn 90deg in order
