Head Check Valve Oil Leak? Dealer Says it's not the Timing Cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by uwjberg, Mar 27, 2022.
  1. Mar 12, 2025 at 6:12 PM
    #41
    Texas-Gorilla
    Texas-Gorilla Well-Known Member
    Thomas
    2016 Tacoma TRD OR
    I'm not planning on removing the lines, just loosening the belt and moving the pump out of the way. I'd rather use too much than not enough, and I'm glad to hear that 10 months later it's still working out for you.
  2. Mar 12, 2025 at 7:18 PM
    #42
    Billsern
    Billsern New Member
    Will
    ‘16 Taco
    Yep I’m definitely guilty of having used this trick before… I’ll give it a try and from the sound of it, the timing cover gasket seems to be prone to failure in general so plan on using rtv along with a new gasket eventually :/
  3. Jun 1, 2025 at 10:43 AM
    #43
    mewefan
    mewefan Active Member
    Did everyone drain the oil before you did this? And how long did you wait after the oil was drained until you made the RTV repair? Essentially, how long did it take to stop seeping oil before you made the repair?
    NoOne likes this.
  4. Jun 1, 2025 at 11:51 AM
    #44
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You don't need to drain the oil. The oil is down in the oil pan just sitting there. Just clean it off really good with brake cleaner, let it dry and then go to town with the sealant
