Head gasket blown 2.7l
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Jan 31, 2021.
  1. Feb 4, 2021 at 3:38 PM
    #121
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Does anyone have a picture of a 3rz back part compared to a jdm
  2. Feb 4, 2021 at 10:09 PM
    #122
    Allex95
    allex
    Does anyone know if the oil Dipstick tube is a problem cause with the jdm it’s on the driver side and on mine it’s in the front of motor. Will this cause issues unable to read oil?
  3. Feb 6, 2021 at 3:35 AM
    #123
    elliott3
    elliott3 Unknown
    in the ozarks
    99 xtracab 4x4 03 dcsb 4x4
    Search my friend it has all been documented with pics.
    JudoJohn likes this.
  4. Feb 6, 2021 at 3:36 AM
    #124
    Allex95
    allex
    Been searching not enough info on it
  5. Feb 6, 2021 at 3:42 AM
    #125
    elliott3
    elliott3 Unknown
    in the ozarks
    Get on the YouTube. One guy made a three part video with tons of information
  6. Feb 6, 2021 at 11:18 PM
    #126
    Allex95
    allex
    For anyone that is still interested in this topic. I’ve look for replacement engines that aren’t jdm with no luck. I did get a jdm motor but some modifications need to be done. One being timing cover because dipstick on jdm is on the side, exhaust and intake. The jdm head has a 4 port and my intake is 8, and pully/accessories. I’m thinking since I need a 8 port head and since my head is good. I saw my head over to the jdm motor put my timing cover on and call it a day.
  7. Feb 7, 2021 at 12:39 PM
    #127
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Can you please document as much as you can? I'm sure it would help others who happen to get this problem later on. Speaking of blown head gaskets.. what's a good way to prevent them? and are they somewhat common for the 3rz?
  8. Feb 7, 2021 at 12:47 PM
    #128
    Allex95
    allex
    Well my engine was shitty rebuilt. Cheap rebuild with costly repairsss
  9. Feb 7, 2021 at 12:48 PM
    #129
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    interesting. I'm just really trying to avoid dealing with a blown head gasket
  10. Feb 7, 2021 at 1:46 PM
    #130
    elliott3
    elliott3 Unknown
    in the ozarks
    If the jdm engine came with an intake use it’s lower half and your upper. Just pay attention to which injectors it has. My engine had brown and my jdm had pink. I used my browns because the pink were higher flow.
    Rachelsdaddy and JudoJohn like this.
  11. Feb 7, 2021 at 1:52 PM
    #131
    Allex95
    allex
    I can’t use the lower intake part it’s all one piece.... I’m either gonna have to swap my head to the jdm for the 8 port or use my 8 port on the 4 port
  12. Feb 7, 2021 at 1:55 PM
    #132
    elliott3
    elliott3 Unknown
    in the ozarks
    I’d try to find a lower half off on 01-04 before I done that. I wouldn’t pull the head on a jdm. I’d buy a short block before I done that. That’s basically all your using anyway.
    Rachelsdaddy likes this.
  13. Feb 7, 2021 at 1:59 PM
    #133
    Allex95
    allex
    I literally can’t find any... still looking. Looked for blocks to but struggljng
  14. Feb 7, 2021 at 2:06 PM
    #134
    Allex95
    allex
    Actually I believe I found one. Only problem now is I have to swap timing covers to get a reading for the dipstick. Do you have a jdm?
  15. Feb 7, 2021 at 2:21 PM
    #135
    elliott3
    elliott3 Unknown
    in the ozarks
    I didn’t have a jdm. I used an 01 in my 99. Timing cover can be swapped without removing the head if you have the oil pan off. I only had intake differences. Does the jdm not have a plug in the timing cover that can be removed for the dipstick?
  16. Feb 7, 2021 at 2:21 PM
    #136
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Look harder. LEAVE THE HEAD ALONE. There’s millions of them. Check EBay motors/parts/
    Abeyancer and elliott3 like this.
  17. Feb 7, 2021 at 2:24 PM
    #137
    Allex95
    allex
    It’s a plug I don’t believe it can be unscrewed it’s a aluminum plug.
  18. Feb 7, 2021 at 3:04 PM
    #138
    elliott3
    elliott3 Unknown
    in the ozarks
    You’ll have the pan off. If it’s a plug try bumping it out.
  19. Feb 7, 2021 at 3:07 PM
    #139
    Allex95
    allex
    I’ll send a picture once I get a chance. Also the head in this 3rz has a camshaft sensor but of course I’m not gonna need it so it shouldn’t be a problem right? I’m using a distributer
  20. Feb 7, 2021 at 8:06 PM
    #140
    Allex95
    allex
    For anyone else I’m kinda wondering. Since my jdm motor has the camshaft sensor in the head does it mean it’s not a 2.7l and actually a 2.4? It has 3rz written on it and it was pulled from a 4x4 car/truck. Has 3rz on the block, but just wondering if it’s even a possibility I got a 2rz instead of a 3rz.
