Head gasket failure on 4.0 Toyota engines
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barley1, Oct 24, 2016.
  1. Oct 24, 2016 at 5:26 PM
    barley1
    barley1 [OP] New Member
    Ian
    2005 Tacoma 4X4
    How many of you have had head gasket failure on your 2005 or earlier 4.0 engine.
    I have been a loyal Toyota sense 1972 and have owned 25 plus Toyotas. The head gaskets on my 2005 Tacoma failed at 139000 miles. I got a case number, furnished Toyota with serial numbers on many of my Toyotas. They said no help at all. What's with Toyota???
    If you or any one you know has had a head gasket failure on their 4.0 engine, notify and bitch to Toyota. They know they have a problem as the corrected the problem in 2006 with no failure after that.
    I married my tacoma likes this.
  2. Oct 24, 2016 at 5:29 PM
    Pigpen
    Dan
    Northwest Montana
    It's pretty rare from what I've seen on here. Bummer you were one of the few.
    Markcal, Sugar Silva and T4RFTMFW like this.
  3. Oct 24, 2016 at 5:32 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I understand a certain level of bitching to Toyota, but things are getting crazy around here. Everyone with a problem wants toyota to start a program to fix it for free. I understand that is early for a head gasket to go out, but old vehicles break down. Think of all the other things you would have fixed on a domestic by now.
  4. Oct 24, 2016 at 5:42 PM
    Pigpen
    Dan
    Northwest Montana
    All the "free" fixes get paid for by future model buyers (which may be you down the road). Nothing is free.
    TheDevilYouLove and boynoyce like this.
  5. Oct 24, 2016 at 5:43 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It's only 103,000 miles out of warranty.
    They should pay.
  6. Oct 24, 2016 at 5:49 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Your truck is 11 years old with nearly 140k on... why is Toyota responsible?
  7. Oct 24, 2016 at 6:02 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Blew the engine (heads) at 83, 000 kms (51k miles) on a 2008 in 2012.
    No help.
    Replaced motor with a 143 km (89 k miles) and got ful trade value. Dealer put the truck on their lot as a fully warrantied vehicle to 100,000 kms.
    I walked away with a new truck for the same payments (+ 2 years) with 7 years/160,000 km warranty bumper to bumper. 5k off sticker.
    I helped myself.
  8. Oct 24, 2016 at 6:08 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You do realize the year is almost 2017, right?
  9. Oct 24, 2016 at 6:08 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    More people demanding free shit not owed to them. :jerkoff:
  10. Oct 24, 2016 at 6:12 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I had early head gasket symptoms at 140k and sure enough it was toast. $3k with new radiator, new water pump etc. whoever told you the problem stopped in 2006 is lying to you, I know someone with an 09' having the same prob right now. It's a very common prob with these motors when hey get into higher digits.
    george101, scottalot and Lilbigman like this.
  11. Oct 24, 2016 at 6:18 PM
    Pigpen
    Dan
    Northwest Montana
    Interesting that it doesn't show up on here often. Not being sarcastic, I just rarely see anyone posting about it.
    Realoldfatguy and scottalot like this.
  12. Oct 24, 2016 at 6:53 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I wonder how many auto mfgs. would pay for a new head gasket on any of their 12 yr. old vehicles with nearly 140K on the clock?
  13. Oct 24, 2016 at 7:16 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    ALOT OF 2005's have had head gasket failure. Some early 2006's... like mine still had old head gasket! Just spent almost $4,000 getting it fixed! I agree, if yours fails... CALL AND COMPLAIN!
    Symptoms are...
    Coolant level dropping
    Water swishing sound from under dash when you first start the truck
    Random mis-fires on cylinder 5 and/or 6
    Abnormal moisture/water dripping from exhaust
    Dealership did pressure testing and found no problems, me and a friend with a shop diagnosed it. I went back to the dealership and asked to have head gaskets changed. They said I did not need to have them changed because their tested did not show any issues. Upon removing the heads... gaskets were blown! I used the dealership for 2 reasons...
    1. Warranty
    2. I know one day there will be a recall :) and I have a receipt!
    (when I first called to complain about factory defect the rep told me if i do get it fixed TO MAKE SURE I KEEP my receipt. The way she said it was like, ya they know there is a problem and something is on the horrizon)
  14. Oct 24, 2016 at 7:32 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    I had to have mine done. I had about an 1/8 spot in the gasket that was giving me an issue. I took it into the dealer and they ran a test and said it checked out fine, The same day I took it to a local shop and they did a test to check for exhaust coming back thru the coolant overflow and there was. The local shop did the work and found the bad spot. I spoke to my dealer and they told me to keep the receipt for the work due to Toyota knowing that there is an issue with most of the 2005 vehicles. If they issue a recall great and if they don't, No Worries. All I care is that it was caught in time and it got fixed.
    jboudreaux1965 and scottalot like this.
  15. Oct 25, 2016 at 7:57 AM
    tgear.shead
    tgear.shead Well-Known Member
    12 years and 140,000 miles.
    Most cars don't last HALF that long.
    Hire a mechanic (not a dealer, a MECHANIC) to do a head gasket job on it.
  16. Oct 25, 2016 at 8:08 AM
    DonL
    DonL Well-Known Member
    Don
    Prescott, AZ
    Tacoma TRD
    Monster Exhaust, Shell, 5100's all around, Airlift airbags, Hankook Atm, K&M air filter
    I had an '89 Toyota, 3.0L engine truck with 98K. It was four years old. Toyota paid for the whole repair for the blown head gasket. Toyota ain't what it used to be!!!
    Athlaos and scottalot like this.
  17. Oct 25, 2016 at 8:09 AM
    tgear.shead
    4 years is still young.
    This guy is talking about an engine that is TWELVE years old.
  18. Oct 25, 2016 at 8:43 AM
    Crosis
    Dunedin Fl
    Entitlement generation: An group that feels a 12 year old engine with 139,000 miles on it should be repaired for free. :facepalm:
  19. Oct 25, 2016 at 8:56 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Wait, was/is there a recall for this? I have an 05 with just under 80k. I don't have any issues yet, but just wanting to know if there's a [Toyota-initiated] fix for it that I should be aware of.
    scottalot likes this.
  20. Oct 25, 2016 at 3:53 PM
    BTlonestar
    BTlonestar Member
    BT
    Austin, Texas
    2005 DCSB 4x4 V6 - Desert Mica
    there's plenty of HG failure posts here. thats how i diagnosed mine. a cyl 6 misfire code lead me to HG replacement just a couple of months ago, on my 11 year old 140K mile 2005 4.0L...
    i had purchased a warranty with my used tacoma when i bought it 2 yrs ago; but the dealer said my warranty does not cover seals and gaskets and they wanted over $4k to replace the HG and a catalytic converter. after some discussion and persuasion i convinced them to figure out a way to get it covered. and they did. not the catalytic converter, but they did replace the HG for a $100 deductible. i wasn't rude or nasty or stubborn- i simply asked them to try harder, to go to bat for me, and to just figure it out. i imagine what the dealer did was claim something else that was covered, like a cracked head, with the warranty company. this way, their customer gets satisfied (which i am) and they get paid. win win... i dont FEEL entitled, but maybe i should...
