Head gasket issues 05 Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oldeskuel, Jan 9, 2016.
  1. Jan 9, 2016 at 10:08 PM
    oldeskuel
    oldeskuel [OP] Well-Known Member
    WA
    05 DCSB, TRD Sport 4x4
    Stealth 6 wheels from SCS; Goodyear duratracs in 265/70/17
    I recently was told that some early versions of the 4.0L V6 are prone to head gasket issues. I own a 2005, and was naturally concerned considering it is the first year of the second gen Tacoma. My research on the issue turned up a bit of information, but not much. Can anyone confirm the existence of potential head gasket failures in early 4.0L V6 engines?
    If there is such a potential problem, is there a way to prevent it from occurring? My 2005 is at 104k and has been solid so far, but I drive it hard and now I'm a bit worried I should be taking precautions to prevent a head gasket failure.
  2. Jan 10, 2016 at 6:20 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As long as you have changed the coolant fluid before it turn acidic not much you can do. Either it will blow and leak or it won't...
    Just be aware of the signs and watch for it.
  3. Jan 10, 2016 at 10:41 AM
    oldeskuel
    WA
    Thx. Still wondering if there is a confirmed issue or if it's just a myth.
  4. Jan 10, 2016 at 1:37 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I have an 05 that just turned over the 100K mark. Never had an issue.
    But from what I have read that the gasket problems seem to start around 150K. I did some reading about coolant and it seems that Asian vehicles are very picky about the type of coolant used. It has to do with the different types of metals used in the engine and how they react with the coolant.
    That being said, I would NEVER use the "fits all" type of coolant sold at parts stores (prestone, peak, etc).
    Keep fresh Toyota coolant in your engine and just cross you're fingers!
  5. Jan 10, 2016 at 2:19 PM
    blitz
    blitz Well-Known Member
    Kevin
    cape cod
    My 05 has 250k miles. No issues
    oldeskuel[OP] likes this.
  6. Jan 10, 2016 at 6:12 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There has been a handful of cases reported here on TW of coolant weeping into cylinder #6, causing a misfire on start-up. I wouldn't call it widespread, but it could be called a known issue. I wouldn't worry about it too much though, it's not a high percentage that are failing. Maintain your coolant, keep your rad clean, don't accelerate hard on a cold engine, you know, the usual stuff.
    Jimmyh and oldeskuel[OP] like this.
  7. Jan 10, 2016 at 8:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The most important part here. Antifreeze will turn acidic / corrosive when they are depleted and eat away at the head gasket.
