Head gasket issues with the 3.4L?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jahwn, Feb 18, 2010.
  1. Feb 18, 2010 at 10:04 AM
    Jahwn
    Jahwn [OP] Active Member
    San Diego
    2004 Tacoma ext. cab 4x4 V6 5spd
    Is the 3.4L engine prone to blown head gaskets like the old 3.0L did?
    I'm hoping to get into a 1st gen Tacoma at some point soon, but I wanted to get some more info about the 3.4L before jumping into one.
    I had a '92 4x4 pickup years ago that was the best truck EVER until it blew a head gasket, and then another, and another, and then a new long block, and then bye bye. Don't want to go that route again!
  2. Feb 18, 2010 at 10:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No. The 3.4 is not known for the issues the 3.0 had.
  3. Feb 18, 2010 at 10:29 AM
    Jahwn
    San Diego
    Thanks Chris. I did some searching and found little about the 3.4L HG's but I wanted to double check.
  4. Feb 18, 2010 at 12:09 PM
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    Hasn't happened to me nor have I heard of it happening with the 3.4s you should be good to go!!!
  5. Feb 18, 2010 at 12:11 PM
    usmrocks
    usmrocks Well-Known Member
    Daniel
    mississippi
    96 tacoma 4wd
    just like she came in 1996
    i had a head gasket blow on the one i had.
    96 3.4. blew out with about 100,000 on it
    straightawaykid likes this.
  6. Feb 18, 2010 at 12:15 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    i have 157,000 on mine with no problems
  7. Feb 18, 2010 at 12:18 PM
    The_Dude
    The_Dude Well-Known Member
    I'm the second owner of my 99 and I guess the guy before me didn't maintain it because the motor blew at 164k. Other than that, I got no complaints.
  8. Feb 18, 2010 at 4:51 PM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
    I had a 96 4Runner with a 3.4L before my current truck; it developed a small head gasket leak when it was about 6 months old. The leak was so small that the coolant with evaporated on the block, never any coolant on the ground. The head gaskets were redesigned at about the same time (late 96), Toyota replaced the head gaskets and because they had the truck for more than 20 days waiting for the redesigned gaskets they provided me with a factory 100k extended warranty. I kept the truck until 2001 and with 95k it had never had another problem. My current 3.4L has 156K and has never had any issues with head gaskets. So I think the redesigned gaskets have proven to get the job done.
  9. Feb 18, 2010 at 4:58 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Im the second owner of a 96 3.4 v6 that has 170,000 on it and it runs great and the guy before me never had to replace anything on it except oil and tires!
  10. Oct 14, 2010 at 1:44 PM
    Moving Chicane
    Moving Chicane Already Gone.
    SoCal.
    2001 with 164,9xx miles and one of the gaskets is starting to leak. Very minor at this point, but still of note. Truck has been maintained only by the dealer and more frequently than the schedule calls for (e.g., oil changes). :( So I bought a 2011. :)
  11. Oct 14, 2010 at 1:47 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i've got 157k on mine (i'm the second owner)... previous owner took great care of it and said it never needed anything more than standard routine maintenance. he changed the timing belt at 90k. runs strong and doesn't leak/burn hardly any oil! i put 6 quarts in and get about the same back out every 3k miles.
    ...woah! didn't see how old this thread was. well, hopefully this comment was useful :)
  12. Oct 14, 2010 at 2:44 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    There was a head gasket recall for early 97's with the 3.4L engine
  13. Oct 14, 2010 at 2:47 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    196k miles here and happy
  14. Oct 14, 2010 at 2:49 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    :rolleyes: The bad headgaskets were for the early 3.4's and were redesigned in 1996 or 1997 something like that. There was a recall.;)
  15. Feb 16, 2021 at 8:49 AM
    Richhol530
    Richhol530 New Member
    Richard
    2000 tacoma 4x4 ext cab 3.4l at ca.
    in 1996 working at toyota dealer the first 3.4l were having headgasket issues simuliar to the 3.0l. but they were redesigned in 97-98 model years but my 2000 now has 260k without any issue (knock on wood).
  16. Feb 16, 2021 at 11:22 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I remember seeing somewhere that from 2001 and forward, a higher quality HG was used. 2000 and prior with the 3.4 MAY have a higher susceptibility to HG issues.
    I have a 2001 Prerunner w/ the 3.4 and I keep up on my coolant change intervals. I'm a sucker for preventative maintenance. No known issues to report.
  17. Feb 16, 2021 at 11:50 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I think the OP would've mentioned a problem if something happened in the last 11years since he made that post:burp:
    Then again he hasn't been on the site since 2012:anonymous:
    Black DOG Lila likes this.
