Head gasket job
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rachealcain57, Nov 15, 2021.
  1. Nov 15, 2021 at 4:23 PM
    rachealcain57
    rachealcain57 [OP] Active Member
    Racheal
    98' tacoma 3.4 v6 5vzfe
    I just completed a head gasket job on my 98 Toyota Tacoma 3.4 l 5vz-fe ...... and when i started the truck it was starving for fuel . I was able to start it finally with some starting fluid.. Heavy raw gas smell coming from engine also and I noticed white smoke coming out of the tailpipe and I'm losing coolant. After I filled the radiator again I noticed that it was leaking coolant from underneath the throttle body
  2. Nov 15, 2021 at 4:41 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You would probably get more/better advice by posting in the 1st gen forums (95-04 model trucks) but it sounds like your truck is either severely overfueling for some reason or your still getting coolant in the cylinders.
  3. Nov 15, 2021 at 4:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you sure you got the coolant lines back on in the correct place on the Throttle Body?
    I believe there are 2 fittings for the coolant line and 1 for a vacuum. It’s been awhile since I messed with a 3.4.
    But I think I remember those lines when I ran a spacer on my TB.
    Dm93 likes this.
  4. Nov 15, 2021 at 5:56 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Those little coolant lines going to the throttle body are small and easily tear. Check the clamps and make sure they're ok
    The Critic and TnShooter like this.
  5. Nov 16, 2021 at 1:09 PM
    The Critic
    The Critic New Member
    I hope you inspected the cylinder heads after they were removed. The 5vz heads like to crack--usually it is one of the middle cylinders.
    DG92071 likes this.
