Head gasket leak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmf21, Oct 1, 2011.
  1. Oct 1, 2011 at 8:59 AM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    I'm crawling under my truck this morning to look at something when I notice this pinkish blob looking thing near the engine below a header bolt. I reach up and break it off and realize it's hardned toyota antifreeze and that I might have a head gasket leak.
    My truck only has 80,000 miles so I'm a bit suprised. What does everyone think. Should I get get it looked at? I'm broke so I really can't get it fixed now but if it's a head gasket leak, how much am I looking at?
  2. Oct 1, 2011 at 9:06 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I can't see well enough but it doesn't look like the head gasket, it looks like just below it. Is there a freeze plug or something there?
  3. Oct 1, 2011 at 9:10 AM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    The freeze plug is almost directly below it and looks fine.
  4. Oct 1, 2011 at 9:10 AM
    Leggo
    Newton,Ma.
    sorry, I see better with my glasses on now. I think you are correct about the gasket . However, If you are not leaking into the c.c. it might be fine while you save up some money. It looks like it has been weeping for a while.
  5. Oct 1, 2011 at 11:58 AM
    Leggo
    Newton,Ma.
    Do you live in a warm state? I would add some block sealer and cross my fingers.
  6. Oct 1, 2011 at 7:39 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I live here in Arizona.
  7. Oct 1, 2011 at 7:55 PM
    CGtaco
    CGtaco Well-Known Member
    Phillip
    07 Tacoma TRD 4x4
    Fog light Mod Total Chaos UCA's Front Icons Rear Icon / res
    I thought I had the same problem at one time. You can get a pressure test on your antifreeze system to give you an idea on how bad the leak is, but all i can say is keep an eye on you antifreeze level and the color of your engine oil. Try maybe an additive like engine restorer. Hope for the best.
  8. Oct 1, 2011 at 9:16 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    My antifreeze level is at the L mark. I don't think I've paid attention to the level before but I will now. I have to wonder how long it has been leaking and if it still is.
  9. Oct 30, 2013 at 10:49 AM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    04 SR5 4x4 TRD Xtra Cab
    CMF21, what ever happened with your head gasket? I have an 04 XtraCab that's had that same pink blob issue for awhile...been monitoring the oil and coolant level weekly, still running like a champ so far.
  10. Oct 30, 2013 at 2:02 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Go to your local parts store and get a bottle of Blue Devil. It will take care of that small amount of leakage. but yes, it is coming from your head gasket.
  11. Oct 30, 2013 at 4:54 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I had the gasket replaced in 12/2011. The repair shop also sent the head out to a machine shop to smooth it out. While they had everything apart I had them do my timing belt and stuff while everything was apart. Since then I haven't seen any leaks in 45,000 miles.
  12. Oct 30, 2013 at 5:38 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Don't second guess. Pressure test then if that is normal, dye test.
