Head gasket or buy a new motor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BubbaTaco324, Dec 10, 2018.
Engine or head gasket
  1. Replace Head Gaskets
    2 vote(s)
    16.7%
  2. Replace Engine
    10 vote(s)
    83.3%
  1. Dec 11, 2018 at 2:39 PM
    BubbaTaco324
    BubbaTaco324 [OP] Active Member
    97 Tacoma 4x4 3.4L
    21502 western Maryland. I've been trying to do the same! Thanks!
    Slashaar[QUOTED] likes this.
  2. Dec 11, 2018 at 3:31 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
  3. Dec 12, 2018 at 8:59 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I'd estimate about 90% of Tacoma owners have similar cracks in their heads and don't know about them. Get it pressure tested, if it holds slap it back on, if not you need a new head. Cost and labor wise you'll be in the same ball park for replacing the whole engine vs redoing all the seals/gaskets and purchasing a new head but the latter will be a fresher engine.
    Edit: On second thought if the machine work on the cylinder requires pulling the engine I see no reason not to just replace it. And it's probably the other way around foe the sequence of events. The coolant leak caused the head to over heat and crack.
    cruiserguy and Slashaar like this.
  4. Dec 12, 2018 at 9:06 AM
    BubbaTaco324
    97 Tacoma 4x4 3.4L
    I have a junkyard throwing power to 2 4runners today to get me mileage and see if they start and idle. If i can get one of these for as cheap as they say, I'll be going this route. If not, I'll probably be getting pressure tested and seeing where i stand after that.
    Thanks everyone for your input, it is greatly appreciated.
    cruiserguy, Slashaar and Hamer95USA like this.
  5. Dec 12, 2018 at 9:12 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Slashaar, Hamer95USA and jammer like this.
  6. Dec 12, 2018 at 9:22 AM
    BubbaTaco324
    97 Tacoma 4x4 3.4L
    Yeah $1200 for a bare head that will still leave me with $500+ in head gaskets and head studs. Then, After that nearly $2k dollar repair, I'd still be left with an old head that could potentially be about to do the same thing and a block that has had water in all the journals, rods, main bearings, crank, oil pump, and any other oiled accessories.. In my opinion that just opens all kinds of windows for future failures.
    At this point I'm leaning to a whole used engine of some sort. Just taking my time and exploring my options so i can find something rather inexpensive and without 250k miles.
    cruiserguy, Slashaar and otis24 like this.
  7. Dec 12, 2018 at 1:25 PM
    Slashaar
    Josh
    Kansas City, MO
    That's what we're here for. :fistbump:
    Well, most of us. :rolleyes:
  8. Dec 27, 2018 at 6:05 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I'm out your way just about every weekend. I have a cabin in WV near Paw Paw.
