Head Gasket Problem! Please Help
Discussion in 'Technical Chat' started by itsjustaliftedXR, Mar 21, 2011.
  1. Jun 27, 2012 at 7:13 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Thats BS...unless there is something wrong with the timing chain tell them to leave it alone.
  2. Feb 9, 2013 at 10:00 AM
    megamole
    megamole Active Member
    05 Double Cab longbed Sport Package
    Westin Platinum Series Tube Steps, Westin Bullbar, Full Metal JackRabbit Tonneu cover, 265/70/17 Nitto Terra Grapplers, Removed back seat storage for a Toolbox, Helwig EZ990 helper springs, weather tech floor liners, custum bed lights
    I too had the misfortune of having a cyl6 misfire and a stumble on start up, water sound in my coolant sytem. It took toyota 2 tries to finally diagnose the bad head gasket.They said it was minor but will get worse with time. I was quoted at $3,500 to change both head gaskets by Toyota.
    I have a V6 dblcab4x4 with 135k and it has never over heated and has been running mobil 1 with 5k miles changes since the first change. I follow all the maintance and do it myself. I said to the service manager how does this happen on a well maintained 8yr old truck with 135k he said time and miles. So Toyota only makes engines that can go 100k in less than 8yrs?? That's crazy that why I bought a Toyota. They let me down big time!
    I then asked the service manager if this happens often on this engine, his answer was no. But I have found a lot of posts with the problem. Has anyone tried Kseal or an equivalant? I am curious if it will work for awhile.
  3. Feb 9, 2013 at 9:47 PM
    BamaToy1997
    Bill
    Navarre, FL
    Head gaskets fail. Plain and simple. I have seen plenty of them, from all different manufacturers. Just like transmission fail, bearings fail, etc. It is the price paid for mass production. No matter how careful you are, when you produce a million parts for a vehicle, you are bound to have failures. And it is not brand specific either. Toyota, Nissan, Dodge, Ford, GM, Mercedes, BMW....I have seen them all.
  4. Feb 18, 2015 at 6:04 AM
    baxter
    baxter Member
    Baxter
    Round O, SC
    2005 Tacoma Quadcab 4x4
    Stock
    Well, I may as well chime in here too. My '05 DC with v6 just developed this exact issue. Rough start in morning then would run fine. Then got a CEL code P0306, #6 misfire. In went new plugs, coil pack. Drove about a week then the cell was back on. Same code. Someone on this forum suggested that I check the coolant level and sure enough it was down. Toyota wanted $3013. Called around to shops and got a wide range of labor hour quotes. No one seemed to had ever done one. Has anyone tried the Blue Devil brand sealant? I've heard several good reviews. Not really what I want to do but I'm in the process of building a new shop and if I can buy say 6-9 months I'll have the equipment to do it myself.
  5. Feb 19, 2015 at 9:59 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I just did mine for ~$800, never having done any engine work before. Well worth the savings if you can do it yourself. I didn't mess with any sealant, went straight to the source.
    http://www.tacomaworld.com/forum/4runners/238998-wishbone-runners-build-16.html#post9549520
    inesshell likes this.
  6. Feb 1, 2016 at 10:02 AM
    shamfrog67
    shamfrog67 Member
    todd
    Woodstock-Ga
    06 PreRunner SR5
    I have an '06 Taco dblcab. 127k miles. Been dealing g with prob for a while. Comes and goes. Got tired of chasing the prob, took to toyota.. bad head gasket at cylinder #2. Quoted me $3300. Going check out local shops around town..
    Seems like enough of a PROBLEM toyota should be taking care of it. Never had ANY vehicle with head gasket probs under 250k miles.
  7. Sep 13, 2016 at 6:18 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I think when you do a search for a particular problem, you will find lots of posts on that problem.
    I too have joined the club at 240k miles.
  8. Oct 21, 2016 at 5:22 PM
    maykups
    maykups Member
    I just brought my son's tacoma DC LB 2005 in and the mechanic has no clue where the coolant is going?? wants to keep it over night to check it in the morning. I see everyone is having the same problem. We have taken care of this truck religiously since day 1 every 5k miles. I will freak out if it is the head gasket and Toyota is aware of this problem on all Tacoma's!!!! Help!!!!! I had to put my son in a rental, they want to keep it overnight. I cannot afford to buy him another $35k tacoma!!!
    Lilbigman likes this.
  9. Oct 22, 2016 at 9:21 PM
    yz450rider
    yz450rider Member
    Just a quick way to check for a leaking head gasket. Disconnect the hose going from the fill neck on the radiator to the overflow tank. Remove the radiator cap, fill the radiator until the fluid touches the ring where the cap seals with the top tank. Leave the cap off and run the engine at an idle. If the head gasket(s) are bad there will be pressure in the radiator from the compression in the engine. This pressure will force the coolant out the neck. Depending on the severity of the head gasket damage, the coolant may burp out right away or it may take a while. Note - be sure there is enough coolant to keep the seal in tact. If not, the compression pressure will simply go out and you will not see the "burp". I know this does not help those with leaking head gaskets but saves buying a tester or worse yet, having to get the test in a $hop.
  10. Oct 26, 2016 at 12:34 PM
    Lilbigman
    Lilbigman Well-Known Member
    2005 Tacoma Double Cab TRD SPORT 4X4
    20x12 Fuel Krank. 33x12.50 Toyo Open Country . 6" FabTech lift. Dirt Logic 2.5 Coilovers front Dirt Logic Shocks rear. Billet grille. Pioneer DVD touchscreen. Hertz 6.5 2 way in front & rear. 3 10" JL AUDIO 10w0 subs. 2 Pioneer amps powering the system. Magnaflow catback single in dual out
    I'm having the same problem with cylinder #4 in my 2005 DC
  11. Nov 1, 2016 at 4:22 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    This makes me nervous of my '05 I just bought with 125k miles roughly on it. I have owned a lot of vehicles with over 300k on the clock and never had a head gasket issue. I'm starting to question the qdr Toyota always brags about. (Mines in for entire frame replacement)
  12. Nov 4, 2016 at 8:01 PM
    Lilbigman
    Update ?
  13. Nov 28, 2016 at 3:59 PM
    OnlyKetchup
    OnlyKetchup New Member
    Just found this site, my .02. I have owned 3 Toyotas, a 1982 4 cyl, a 1993 V6, and a 2005 V6. All were sold when the next one was bought. The 4banger was great and sold me on Toyota, never had any problems with that truck, maintenance only. Moved up to the '93 king cab V6, great truck, same deal, no issues, EXCEPT, around 2000, (have to check) head gaskets went bad, 1200.00, but Toyota paid for it (recall, tsb, whatever you want to call it). Paid it no mind, and bought a double cab in '05. Great truck, low and behold, 135K later, #6 misfire, CEL, and they want 3700.00 to fix it (no tsb's now, apparently they fixed it - my ass). I have been tried and true Toyota all my life, but I am thinking Silverado. I see ALOT of disappointed Toyota owners on the web with head gasket problems from '98 - 2005/2006.
    My question to the motorheads, did they finally fix the head gasket problem in the newer Taucomas, what say ye?
  14. Nov 28, 2016 at 4:41 PM
    Northern Taco
    Toyota updated the part number on the later 2006 on up 4.0l Toyota engine. It seems to be '05 and early build '06 4.0l that have head gasket issues. But I'm hoping not all of them have the issue, which I think is a possibility.
  15. Apr 28, 2017 at 9:06 PM
    #35
    Amike
    Amike Member
    2005 Tacoma prerunner
    2005 Tacoma prerunner.
    Yep little bubles in the radiator fluid, losing 6 oz of coolant a week. The dealer mechanic will watch it and makes up excuses! Now missfires in the morning, sometimes in the day. This has been going on for a year. 189,000 miles and Toyota wont admit they have a 3,500 problem! Code PO302 i had to get a code reader to see what keeps coming up. Why wont they diaganose the problem, first the spark plug, then then the coil, now the injector? BS first brand new car i ever owned.never again Toyota!!!
  16. Apr 29, 2017 at 5:31 AM
    #36
    Northern Taco
    It's definitely a piss off. I would put some head gasket stop leak in myself. $3500 on a 12 year old pre runner doesn't make sense to me. I know people will flame away on me, but a small leak can be fixed with some of those treatments.
  17. Apr 29, 2017 at 8:51 AM
    #37
    Amike
    Amike Member
    Thanks Northern, thats the only thing i can do. The first month i had it all the mud flapps ripped off due to thin casting. They wouldn't cover that either i paid. Two months ago they did the racall on the rear leaf springs at least that was covered but did not want to address the head problem then again. I just feel like there giving me the middle finger for being a loyal customer and always dealer maintained.
  18. Sep 30, 2017 at 3:09 PM
    #38
    Drew12
    Drew12 Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    I have the same issues... Except no CEL yet.... Does this mean I am good, or it hasnt been bad enough for the CEL to go off? The only reason I think that my head gasket is bad, is that I have alot of oil build up on the passenger side of my engine. Also, my coolant makes a gurgling sound on cold mornings and my overflow reservoir levels are constantly all over the place on a daily basis. I will try some ATP AT-205 reseal in the crankcase and see if this solves the issue... If I even have one. I just hate to take it in to the dealership to have them look at it because I know they will pick out all sorts of "problems."
  19. Nov 20, 2017 at 5:56 PM
    #39
    maykups
    maykups Member
    My Tacoma has the same issue of #4 AND #6. Now they are saying it possibly is the head gasket. Now they want $3k to repair. I do not have the money!!
  20. Nov 20, 2017 at 7:52 PM
    #40
    Drew12
    Andrew
    Sisters, Oregon
    I got quote
    I got quoted $1750 for a timing chain cover re seal. Don’t go to Toyota to get it done. Get it done by a trusted shop. Also got quoted $600 for a wheel bearing replace. It’s something that will cost $175 max to do myself. Don’t trust Toyota quotes
