Head gasket question
Discussion in '1st Gen. Tacomas (1995-2004)' started by mnfeo2, Mar 12, 2017.
  1. Mar 12, 2017 at 7:30 PM
    mnfeo2
    mnfeo2 [OP] Member
    02 Double Cab
    Ok, I did a search, a couple, and I cant find the exact symptoms my truck is having.
    2002 Tacoma 3.4 4x4 supercharged
    The cooling system is always pressurized even when its cool/cold, except when i relieve the pressure. About 10-15 seconds after starting the motor with the radiator cap off the coolant starts to overflow. I have not seen any bubbles in the cooling system and it does not over heat. The temps run about 175-182 with a 170 thermostat. I do get a smell of coolant when I start the truck and found the radiator to have a couple pin holes at the bottom. It will be replaced later this week along with the thermostat just for good measure. The rad cap is new and in working order. I have a cooling system/rad cap tester.
    One of the searches suggested the head gaskets might be in question. I did a compression test today, below are the results. The truck runs fine and pulls well.
    1 - 165
    2 - 125
    3 - 135
    4 - 150
    5 - 145
    6 - 125
    I'm not sure if the low compression is due to the rings or the head gasket being shot, or both.
    Please help!
  2. Mar 12, 2017 at 7:34 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    How many miles? Do you know how long it has had the SC on? The head gasket is a far more common issue with the 3.4 than the piston rings from what I can tell. How long has it been since the water pump and timing belt have been changed?
  3. Mar 12, 2017 at 7:41 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    My Ford interior started smelling like radiator fluid when my heater core went out. Then my head gaskets started going out after that. I drove around for a long time with the heater not working.
    I'm not sure if this helps out with Toyotas or not.
  4. Mar 12, 2017 at 7:43 PM
    mnfeo2
    mnfeo2 [OP] Member
    02 Double Cab
    145,00 miles, the supercharger was installed about a year ago at 130,000 miles. The water pump and timing belt where changed last April at 135,000 miles.
  5. Mar 12, 2017 at 7:49 PM
    gmr102
    Utah County
    Ok. My money would be on the head gasket. I'm sure a new radiator and thermostat wouldn't hurt anything either as you already plan to do both. Have you checked the oil out as well to see if it has water in it?
  6. Mar 12, 2017 at 9:19 PM
    1997tacomav6
    Denver
    Keep an eye out for white smoke from the tail pipe and ANY missing radiator fluid.
    If you see either of these issues then the head gasket is the problem, the compression does show a problem,
    My head gasket went out at 489,000, white smoke, just a little radiator fluid loss.
    Supercharged the whole time,
    Maybe you will find some info on my posting when it happened to me below
    https://www.tacomaworld.com/threads...epair-or-replace-engine.397363/#post-11004749
  7. Mar 13, 2017 at 12:07 PM
    mnfeo2
    mnfeo2 [OP] Member
    02 Double Cab
    I don't get any white smoke/steam out of the tail pipe. A fellow toyota guy at work recommended running it to TDC and hooking up an air compressor to help figure out what is leaking. I'll be doing this when I get home.
