Head gasket question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justin723, May 10, 2010.
  1. May 10, 2010 at 8:52 AM
    Justin723
    Justin723 [OP] Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    Which would do you guys suggest i use. The new multi layered graphite head gasket or the multi layered steel headgasket.
  2. May 10, 2010 at 11:51 AM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    steel :D
    The first head gaskets were manufactured
    of asbestos fibres, covered
    with thin copper sheets and reinforced
    with metal beads around the combustion
    chambers. Up to the end of the
    80's, the development of head gaskets
    was dominated by asbestic materials,
    later rolled onto steel mesh or perforated
    sheets. Following the ban on asbestos,
    head gaskets were produced
    in practically the same way, but using
    asbestos-free materials (AFM).
    By 1992 VICTOR REINZ had already developed
    and launched the first series-produced
    MLS head gaskets. Today, these gaskets
    are state-of-the-art, and enable development
    engineers worldwide to implement
    innovative new engine concepts.
    MULTI-LAYER STEEL OFFERS
    HIGHER SEALING POTENTIAL​
    MLS head gaskets consist of two to
    five sheets of spring or carbon steel,
    which are sandwiched with the sealing
    material to form multi-layer steel head
    gaskets. For improved sealing of gases
    and liquids, beads around combustion
    chambers and oil/coolant passages increase
    the local sealing pressure (macro
    sealing), whilst full-surface or partial
    elastomer coatings provide additional​
    sealing tightness (micro sealing).
  3. May 10, 2010 at 2:54 PM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Thanks man. Great info by the way.
