Head gasket repair
Discussion in '2nd Gen. Tacomas (2005-2015)' started by itaco, Feb 11, 2014.
  1. Feb 11, 2014 at 11:08 AM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    I have a 2005 tacoma with possible blown hs. Was wondering if anyone has repaired one and how much it cost. I just need a rough estimate. Thanks
  2. Feb 20, 2014 at 5:14 PM
    7A7ER
    7A7ER FLYNN LIVES!
    AL
    '05 Radiant Red Tacoma XCab PreRunner TRD
    Removed Step Bars, Hood Visor, OEM Bed Mat, Window Tint, Fog Lights Anytime, BFG All-Terrain KO2s, Removed Mud Flaps, Add A Leaf Recall, Color-Matched Grill and Bumper& Plasti-Dipped Badges!
    I have the same problem with my 2005. Dealership estimate today was $2,500 - $2,800 dollars to replace the head gasket.
    I will be doing this myself as soon as weather and secondary cars permit. Worst case scenario, replacing head with used one for around 300 or less and a lot reading, perusing this site, scratching my head, bleeding and cussing.
  3. Feb 20, 2014 at 7:13 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    4cyl or 6cyl? My son's '98 4Runner with a 4cyl cost about $300.00 in parts and a 12 hour day to fix. I'm not sure about a 6cyl but I'd imagine it should be about the same, that is, if your doing the work yourself...
  4. Feb 20, 2014 at 8:55 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    though they really aren't line by line, a Haynes or Chilton will really give you an idea of what you may be getting into. anything is possible if you put your mind into it.
    just remember, all you have to do is take it apart, and put it back together. think about the poor bastard that designed it!
  5. Feb 21, 2014 at 1:30 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    Apparently there's an issue with the 05 tacomas, fj, and 4 runners. They all seem to be failing at cylinder 6. I got quoted at $2400 and I'm from Hawaii so I guess that reasonable.
  6. Feb 21, 2014 at 2:05 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    $40 for a can of sealer for 2004 Sporttrac. It works better if you use pure water and not coolant. External leak only. Still holding at 15k.
  7. Feb 21, 2014 at 2:11 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    What is a HS???????? Head seal? Head something or other??? Head stuff??
    From the responses and the title, I assume it is a head gasket but I have know to be wong.
  8. Feb 21, 2014 at 6:42 PM
    itaco
    itaco [OP] Member
    Hawaii
    05 Tacoma
    Bwahaha oh shit. Didn't even notice that. Head gasket
  9. Jun 1, 2015 at 4:12 PM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    Is there a way to positively assert that one or both head gaskets are blown before lifting the engine cover and doing all the work ? my 2007 V6 is showing some possible indications (as per this thread) but I don't get "frothiness" on my oil dipstick. check engine code is P0010
  10. Jun 1, 2015 at 4:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    More definition please. :)
  11. Jun 1, 2015 at 4:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    Big factor will be if the head is damaged or not. And you won't know till you remove it.
    On another marquee a fully rebuilt head was about $200 more than moving my components to their fresh head. So that was my choice. If it's a v6 and that level of attention was needed, AND it was high miles AND compression work showed any sketchiness on the other bank, I'd do both and have the whole top end refreshed.
    http://www.cylinder-heads.com/ was my source, not affiliated, etc etc.
