Head gasket replaced, same issue months later
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Apr 21, 2023.
  1. Apr 21, 2023 at 4:01 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    5VZ-FE 3.4L V6 - 225k
    Long story short: Back in October I had the head gaskets and all other gaskets replaced (OEM). Reason, after a comp test, there was an issue with cly #4. Coolant was leaking into 4 ever so slightly. Heads were resurfaced too. So back in Feb I noticed the coolant level in my jug being a tad low, so I added. I had to add a few times (cup or so). Took it to my Toyota tech yesterday and it turns out it's leaking in cyl 4 again, same issue as before. It's such a small amount too. No, it is not touching my oil. My guy is straight as an arrow and I have used him for 5 years. His work is solid through and through.
    So now what? All OEM parts, heads resurfaced, and all torqued to spec. Could there be an issue with the small block, the heads again, who the hell knows with my luck.
  2. Apr 21, 2023 at 4:24 AM
    treyus30
    treyus30 cntl-y
    Trey
    Mesa / AJ, AZ
    '99 5VZ-TT 14PSI+
    Two spooly snails, Haltech 2500, 35s, 125kmi
    Heads were resurfaced but not the block. Depending on how long the leak was there, there could be sufficient pitting or deformation on the block itself as well. Without seeing pictures from the job, it's hard to tell without taking it apart again.
    joba27n and vettehigh[OP] like this.
  3. Apr 21, 2023 at 4:36 AM
    vettehigh
    Jon
    Upstate, NY
    You said what he thought yesterday :thumbsup:. Just hate to spend all this money again and time
    So to resurface the block, the whole engine has to be removed and would I have to replace all OEM gaskets again?
    treyus30[QUOTED] likes this.
  4. Apr 21, 2023 at 4:38 AM
    treyus30
    treyus30 cntl-y
    Trey
    Mesa / AJ, AZ
    '99 5VZ-TT 14PSI+
    If he's as good as you say, that should be warrantied work.
  5. Apr 21, 2023 at 4:42 AM
    treyus30
    treyus30 cntl-y
    Trey
    Mesa / AJ, AZ
    '99 5VZ-TT 14PSI+
    Ideally, yes. Just head gaskets and head bolts are the requirement imo, though the FSM is going to say all gaskets. There's a chance the block surface just needed a good cleaning and he didn't do it, now the HG is making a poor seal. When I did mine, I spent about 10mins per bank with a drill and one of these: 3M 3M-18733 Roloc Bristle Disc Grade - 120, Size - 2 https://www.amazon.com/dp/B01MSU3PYQ
  6. Apr 21, 2023 at 4:43 AM
    vettehigh
    Jon
    Upstate, NY
    But if it's an issue with the block, does that fall on him?
  7. Apr 21, 2023 at 4:45 AM
    treyus30
    treyus30 cntl-y
    Trey
    Mesa / AJ, AZ
    '99 5VZ-TT 14PSI+
    If he did all the work without checking that (essentially fitment) before putting it back together, that's not on you....
    They make measurement tools just for checking surface straightness
  8. Apr 21, 2023 at 4:45 AM
    vettehigh
    Jon
    Upstate, NY
    He did the cleaning also, he is OCD like myself. He goes overboard.
  9. Apr 21, 2023 at 4:48 AM
    vettehigh
    Jon
    Upstate, NY
    Like you said, lets see when its apart to find the issue before I cast blame
  10. Apr 21, 2023 at 4:50 AM
    treyus30
    treyus30 cntl-y
    Trey
    Mesa / AJ, AZ
    '99 5VZ-TT 14PSI+
    Sounds good. Others may chime in and say it's time for a lower mileage replacement engine.
    vettehigh[QUOTED][OP] likes this.
  11. Apr 29, 2023 at 5:15 PM
    herrindude
    herrindude 1996 2.4 extra cab auto
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    My 2.4 217000 miles had a leaking head gasket, exhaust in radiator. No oil and coolant crossover. Tested with tester. I am going to do a head gasket job but for now i used blue devil head gasket sealer and no more leak. I know this is not the best way but until i get a chance this will have to do. If it loads here is a video of after treatment and the blue never changed to yellow like it did before treatment
