Head Gasket Replacement 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kerrigan911, Feb 24, 2017.
  1. Nov 28, 2019 at 12:20 PM
    #41
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Best way to clean the mating surfaces then? About to start HG Replacement on my first gen, glad I saw this as I thought the Roloc was the way to go.
  2. Nov 28, 2019 at 1:09 PM
    #42
    Mehullica
    Mehullica Well-Known Member
    Central California
    05 Prerunner d-cab
    I’ve always used a razor blade & brass/stainless wire toothbrushes with gasket remover spray or brake cleaner. Takes a long time but the end result is a better than the messy abrasive method
  3. Jan 2, 2020 at 11:21 AM
    #43
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Coming late to this post, but for those of future reference, Gasket Masters did a great YouTube step by step of replacing the HG on the 1GRFE.
    https://youtu.be/pIbeoMpGxEc
  4. Feb 23, 2020 at 3:11 PM
    #44
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    How likely is it for the engine block decks need to be resurfaced? I have been losing coolant and have driven it a 2-3k miles without any overheating. I can do the head gaskets but it will suck if the block needs to be resurfaced as-well which means better to put a replacement motor. Would like to just do heads.
  5. Feb 23, 2020 at 5:03 PM
    #45
    specter208
    California
    What is the max allowable warpage that is within spec?
  6. Feb 23, 2020 at 6:08 PM
    #46
    JBCjr
    JBCjr Well-Known Member
    Phila
    06 PreRunnerTRD
    I was told for the 2nd Gen 4.0 heads, its 0.1mm. Are you asking for a 3rd Gen motor?
    Are there any other symptoms?
  7. Feb 23, 2020 at 6:49 PM
    #47
    specter208
    California
    I have an 05 Tundra with the 4.0, it is consuming coolant and missing when cold. I am thinking head gasket will be cheaper if I do them myself rather than buying a replacement motor. Resurfacing will drive up the cost and the engine has 152k miles, not sure what the better option is.
  8. Feb 24, 2020 at 7:40 AM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A lengthy procedure, but if you have the tools, time, and guide, not to hard.
