Head Gasket replacement cost 3.4l
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmf21, Oct 21, 2011.
  1. Oct 21, 2011 at 12:44 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    About a month ago, I discovered my head gasket was leaking from the pink blob hanging off the engine below the drivers side header. I picked it off and have been keeping an eye on it. Well I checked it again toady, and it's back.
    Can anyone give me a ball park figure on what it might cost.
    I'm at 82,000 on the odometer and figure I should probably just go ahead and do the timing belt replacement, etc at the same time so I won't be paying for extra labor.
    Just had a thought. Does anyone know of a cheap aftermarket warranty / maintenance agreement. Maybe it'll be cheaper to purchase one and save me some money
  2. Oct 21, 2011 at 12:47 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    that sucks, if you have to pay someone Im thinking around 1k? not really sure though.
  3. Oct 21, 2011 at 12:47 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Does Toyota sell the Head gasket separtely, might have to buy the whole gasket kit, Do the waterpump with the timing belt.
  4. Oct 21, 2011 at 12:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I would just go aftermarket if thats the case.
  5. Oct 21, 2011 at 12:59 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    If I'm going to have it done, I'm going to have everything done at the same time. I'm broke but don't want to pay someone again just to replace the timing belt, water pump, etc.
    I now also have a noise / feeling that just started this past week on my drivers side. Feels like and sort of sounds like I just drove over one of those plastic road dividing markers. Seems to happen at low speeds below 35.
  6. Oct 21, 2011 at 3:52 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    How about some of this: http://www.barsproducts.com/1100.htm
    I've never used it or anything and honestly never would, but if your broke it might help you out for a while. Someone on here probably knows a bit about it or other products like it.
  7. Oct 21, 2011 at 4:15 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I thought about using something like that but I don't really want to unless i know it's not going to screw something up.
  8. Oct 25, 2011 at 12:12 PM
    tacoman78
    tacoman78 Well-Known Member
    Bakersfield, CA
    02 Limited Dbl Cab Prerunner
    Deck Mod
    Absolutely depends on what part of the country your in and what the over head of the shop is. Beyond that there are several other variables to take into consideration. How long have you driven the truck with the damaged gasket? What kind of weather have you been driving it in? and many others. What some people don't understand is that a head gasket is under extreme pressure from the head itself. Most head bolts are torqued between 150 and 250 lbs. If your head gasket breaks it causes a void between the block and the head. The heat from the engine can sometimes deform the head or the block to fill the void. Doesn't happen all the time but it can happen. Over time there is a lot of damage that can be done to the block as well as the head through normal driving. When you replace the head gasket, it's always recommended that you have the block and the head resurfaced so that you have a nice smooth surface for the gasket. You don't want there to be any voids not filled by the head gasket, cause then you get leaks or air in the system, neither is good and neither is a cheap fix.
    Now that my doctoral thesis is complete, it's tough to say what the total cost to replace the gaskets would be, could be $600 could be $1500+. There's just too many variables to account for.
  9. Oct 25, 2011 at 12:21 PM
    98tacoma27
    Ben
    Not Beech Creek
    You sure it's the headgasket? You'd have other issues than just a "pink blob".
  10. Dec 1, 2012 at 1:35 PM
    haneyjbh
    haneyjbh Member
    2001 extended cab 4X4 stock
    JBA cat back stainless exhaust, and rear view mirror air freshiner. Misc URD parts
    I have a 2001 V6 with a leaking head gasket that I am about to undertake. I will take pictures and post a instruction.
    TBA.
  11. Dec 2, 2012 at 8:02 PM
    Hawaiian05
    Hawaiian05 Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    Thatbwould be great if you documented it w/pics.. My '04 has the same issue as the original poster's engine, leaving pink crust on the gasket.. Much appreciated!!
  12. Dec 3, 2012 at 5:51 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    i think mines leaking too, i just did an oil change after many months overdue, and the oil came out very milky and slightly brown (red coolant tint)
    it also smokes white for the first while when started :(
  13. Dec 4, 2012 at 12:11 PM
    BamaToy1997
    Bill
    Navarre, FL
    Aluminum heads tend to be pretty forgiving as far as heat goes. If you are talking about a small amount of coolant leak, then I seriously doubt that you will need to deck the block or heads. Decking the block is a pretty expensive venture, as most machine shops will not do it on an assembled block. This means you would have to remove the engine, and strip the block down to the bare castings. Over my 30 years of working on engines, I have only ONCE decked a block, and that was because I bought a block from a junk yard where the surface had been pitted due to rust. Heads are another story, but while I have had to have steel heads resurfaced, I have only replaced heads on three jobs. One was when a spark plug pulled out the threads (I don't like thread-serting in a head) and the other two were because a customer drove their car over 3000 miles with a blown head gasket, while adding water to it every couple of hundred miles.
    OP, as someone else had mentioned, cost will vary from what part of the country you are located in. The current labor time for replacing head gaskets is 10.5 hours. Adding a timing belt and water pump SHOULD only increase the labor time by 0.7-1.0 hours. As far as parts prices, those also can vary. Parts for a job like that at my shop would be in the $175-$250 range, depending on the quality of the water pump and belt. Labour would be $550. Hopefully that will give you a bit of an indication of how much you may need.
  14. Dec 11, 2012 at 6:21 AM
    BamaToy1997
    Bill
    Navarre, FL
    Depending on the area that you live in, $1k is not an extreme price at all. at a 10.5 hour job, if their labor rate is $80 per hour, you are looking at $800 in labor, and $200 in parts. $80 per hour is about average for a dealership.
