Head Gasket Replacement Job - What Other Swaps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zatara1848, May 16, 2024.
  1. May 16, 2024 at 7:01 PM
    Zatara1848
    Zatara1848 [OP] Active Member
    Edmund
    2007 Tacoma Access named CHARIOT
    Besides water pump and coolant thermostat, what other parts would you recommend getting swapped out during a head gasket replacement job?
    Engine has 93k miles, but thinking long term...
  2. May 16, 2024 at 7:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Honestly thats all you need aside from every seal. A fresh drive belt and spark plugs wouldnt be a bad idea.
    The timing chain tensioners if they are flaccid/have no tension.
    It's a fairly routine head gasket as far as "modern" engines go.
    Zatara1848[OP] likes this.
