Head gasket replacement on 1996 3.4V6 Tacoma--possible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ZRJTacoma, Oct 8, 2009.
  1. Oct 8, 2009 at 2:42 PM
    ZRJTacoma
    ZRJTacoma [OP] New Member
    OK, I recently had a water pump installed, I think the guy screwed it up becuause the other day, I accidently overheated the motor--blowing the head gasket. I noticed too late that it was overheated and there ya go---dunzo!
    Anyways, I took it into a different mechanic and he claims that a new motor is needed---a new head gasket isnt an option--he claims he cannot install one here.
    I always thought that if a head gasket was blown, a new one could be installed with a hone or flattening of the head--this would create the seal necessary to fix the problem.
    Am I off here, why couldnt it fixed with a new head gasket?
    Why do I need a whole new motor?
    Would it be possible that the head is so far gone that either a new or rehoned head and/or head gasket would not work?
    Thanks for the help!
  2. Oct 8, 2009 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont see why it couldnt be fixed...Check with a different shop.
  3. Oct 8, 2009 at 4:36 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Got a little warm huh? Did you drive it till it just stopped or did you turn it off? In any event unless theres a rod sticking out of the block or the block is cracked I don't know why your guy told you a new motor is required , get those heads magnafluxed, check for cracks,warping(if within limits they can be resurfaced & re installed. Also flush out your engine oil(I'm pretty sure it looks like a milk shake color wise (water in oil) & be prepared to buy a set of lifters. If you had a shop install the water pump they could be liable for some if not all repairs, its their responsibility to let your truck warm up (but not over heat) to check their own work for leaks had they done this they would have noticed overheating & trust me, they would have told you about it to cover their asses at time of payment..good luck..:cool:
    P.S. I would have a different shop do the work if possible
  4. Oct 8, 2009 at 4:46 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    Well, I will let you in on a piece of information I found out first hand while trying to install head gaskets on the same motor. The block of the engine gets warped. Found out from a toyota tech that this was a common problem..if it wasnt warped too bad you could get away with taking a file and filing it back flat...but he told us most of them ended up getting short blocks. Long story short is we had to call it on that truck I was working on as it was just too warped to file back flat (im sure it could have been machined) but too much money had already been put into it for what it was and we ended up selling the truck as is...soo It is very true you may need an engine...overheating these engines is not a good thing..Like I said we put 3 head Gaskets on and 3 different heads all with the same result..water in #3 cylinder...and actually the last head we put on was the worst..my buddy got tired of screwing with it
  5. Oct 8, 2009 at 4:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its a cast iron block...Its gonna have to be run pretty dam hot to cause it to warp.
  6. Oct 8, 2009 at 5:09 PM
    mas32259
    mas32259 Well-Known Member
    NEPA
    2010 SR5 TRD Sport
    TRD short throw shifter, Eibach 1.6" lift coils 5100's on all corners, Ipod interface, Painted engine cover, radiator cover, skid plate, speaker grills overhead console, and added carbon fiber and chrome interior trim (Too much cheap plastic) TRD cat back, LED 3rd brake light. 100 lbs of sound deadner. Infinity ref. 6 1/2 all around. OBX pedals and shifter. DTRL mod, Alt. turn signal mod, LED's in glove box and console, LED's under dash lip and back A/C vent,Weather Tech mats. Took off antenea for wind noise
    Any head can be shaved, not filed, you may need a thicker gasket to retain the compression ratio. But the question remains....... WHY did it overheat after a new water pump? The shop should be held liable.
  7. Oct 8, 2009 at 6:04 PM
    TRDKenE
    Kenny
    Richmond, Virginia
    We had the heads magna fluxed and machined...I am talking about filing the block. I've been working on cars for 11 years professionally and believe me it goes against everything I know to take a bastard file to an engine block..but that's whay the yota tech told us that toyota told the. To do verbaly..nothing was ever published abot it..believe me I hadn't been told by a reliable source to do so I wouldn't thrw it up here to look like a retard.
  8. Oct 8, 2009 at 6:08 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    God I'd probably really consider having a shop do a head gasket on a V6. I spent 2 whole days just replacing the timing belt on a V6 Avalon engine. That required removing half the intake. Those Toyota V6 engines are a pain in the ass.
  9. Oct 12, 2009 at 9:03 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I would look into why your motor overheated. The first shop who did your waterpump could be liable. it'll probable be a big hassle but could also save you a lot of money
  10. Oct 12, 2009 at 9:05 AM
    matthew5olson
    matthew
    pittsburgh, PA
    oh and welcome to tacoma world. Where do you live btw. There may be a TW member close by that could help you out.
