Head gasket screw up
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tbone80, Aug 16, 2021.
  1. Aug 16, 2021 at 1:12 PM
    Tbone80
    Tbone80 [OP] Member
    Trent
    99 tacoma 2.7 4wd single cab
    Arb bumper
    My friend is putting in a head gasket and used some fine sandpaper to clean the old gasket off the surface of the block (the head was done professionally). He then realized that was a bad idea. Anyone know what he should do to clean up his mess?
  2. Aug 16, 2021 at 1:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Aug 16, 2021 at 1:35 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    A shop vac.
  4. Aug 16, 2021 at 1:36 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    If the block is aluminum you could have an issue but if it's an iron block don't worry.
    BassAckwards likes this.
  5. Aug 16, 2021 at 1:43 PM
    Tbone80
    Tbone80 [OP] Member
    Trent
    Arb bumper
    Since none of the cylinders are at Tdc, what about pouring some gas into the cylinders and swirling it around to pick up some dust and then vacuuming it out?
  6. Aug 16, 2021 at 1:49 PM
    JudoJohn
    St. Louis
    Why gas? Just vacuum it out. Vacuum and then wipe it out with a towel and alcohol.
    Don't over complicate it. Gas may cause a fire, and will ruin your vac.
    treyus30 and Abeyancer like this.
  7. Aug 16, 2021 at 1:53 PM
    Tbone80
    Tbone80 [OP] Member
    Trent
    Arb bumper
    Im worried about if dust got down along the side against the rings
  8. Aug 16, 2021 at 1:57 PM
    JudoJohn
    St. Louis
    A little dust won't kill it. gas won't get the dust out anyway. And, it would go into the oil and dilute it.
    Abeyancer likes this.
  9. Aug 16, 2021 at 1:59 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    ^^ This.
    Get a long snout air gun with as narrow a nozzle as you find and a shop vac. Cover up everything except the cylinder you're working on, and blow the air down the side of the piston, and have the hose adjacent to 'grab' anything the air blows up. Aside from that, I wouldn't worry too much, the metal particles are going to be VERY small and shouldn't do any damage.
    JudoJohn likes this.
  10. Aug 16, 2021 at 2:06 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
  11. Aug 16, 2021 at 2:09 PM
    stevesnj
    Just use compressed air or if you don't have a compressor use that canned air then wipe the area with acetone with a lint free cloth and you're good. Don't use gas or diesel on the top of the block surface.
  12. Aug 16, 2021 at 2:12 PM
    Tbone80
    Tbone80 [OP] Member
    Trent
    Arb bumper
    Thanks fellas. Its a 3rzfe so it has a iron block. Ill blow and suck till i cant blow and suck anymore and hope for the best. I dont think i hurt the surface im more worried about the dust. Wish i wasnt such a moron
  13. Aug 16, 2021 at 2:14 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Dust will just burn and flow out the exhaust when you start the engine. Just get the bulk of it and any large particles out. Key thing is making sure you didn't ruin the mating surface, so focus on that.
  14. Aug 16, 2021 at 2:18 PM
    stevesnj
    You had me at blow
    Junkhead and JudoJohn like this.
  15. Aug 16, 2021 at 2:19 PM
    JudoJohn
    St. Louis
    :rofl::rofl::rofl:
