Head Gasket Warning Signs? (4th gen)
Discussion in '4Runners' started by Clay_916, Nov 2, 2016.
  1. Nov 2, 2016 at 12:58 PM
    Clay_916
    Clay_916 [OP] Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Hey guys, in the market for a 4th gen 4runner. I'm noticing a lot of talk about head gasket failures on the earlier models 03-05. I'm curious if there are any warning signs to look out for or any indications that a head gasket job is in the near future? Thanks!
  2. Nov 2, 2016 at 7:05 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Bubbling noise from the dash, low coolant and finally the CEL with P0306. Usually around 160k or so. Only an issue on the V6.
  3. Jan 4, 2017 at 10:59 AM
    Ben550
    Ben550 Well-Known Member
    2012 TRD OFF ROAD
    The head gasket issue is way overblown. I had an 04 with 170k miles. I was worried about the HG going so I sold it... 200k plus now and the guy I sold it too is happy as could be... no issues... I wish I had kept it. On the other hand I purchased an 06 V8 and would never do that again. Way more costly "issues" (Secondary Air Induction Pump, Cracked Exhaust Manifolds, Timing Belt) with the V8 than the V6... I would only buy a 4th gen V6.
  4. Jan 7, 2017 at 5:18 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I certainly wouldn't preemptively replace it, definitely not sell the vehicle, but it is a real issue that needs to be dealt with if it pops up.
  5. Jan 13, 2017 at 10:25 PM
    Booster
    Booster Well-Known Member
    1999 TRD 4Runner
    Bilstien Shocks 2.5 Inch Lift TRD supercharger TRD Exhaust Transmission Cooler K&N Intake Aftermarket headers Performance Parts Progressive Springs
    Head gasket experience here. I am running a supercharged 99'. All engines act similar though- and go figure the blower will blow the gasket faster.
    Warning signs are gradual if you aren't a redline driver. Your car will start a lot rougher. Usually what happens is the coolant leaks into a cylinder, and misfires a bit. It's certainly not an instantaneous problem, and definitely don't try and fix it before it happens.
    My bigger problem was one of my headers actually cracked. That was a big issue.
    Just 'smell' your engine. Your nose is a sensor. If you smell lots of coolant/oil, there's a chance you've got a problem with the gasket given all the hoses are tight/radiator isn't leaking.
    Just give the car a bit of gas and run to smell the engine. You will smell sulfur, that's a given so don't panic.
  6. Jan 13, 2017 at 10:47 PM
    Booster
    1999 TRD 4Runner
    I found that the exhaust will have an off white color of your gasket is going. Usually because a little bit of coolant seeps through the gasket into the piston. Should have a sweet smell it's coolant.
  7. Apr 23, 2017 at 10:03 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    there is no problem with the 05 its the 03 and 04 and older years that had issues 05-09 use a different head gasket that doesn't have known failure issues
