head gaskets?
Discussion in 'Performance and Tuning' started by Sky, Oct 11, 2014.
  1. Oct 11, 2014 at 7:20 AM
    Sky
    Sky [OP] Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
    What a good set of head gaskets that dosent cost a arm and a leg?
  2. Oct 17, 2014 at 12:06 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    If there is somewhere to save money, HEAD GASKETS AINT ONE OF EM!
    I would suggest an MLS Cometic pair of gaskets, they last pretty much forever. Not the cheapest, but IMO the best.
  3. Oct 18, 2014 at 12:37 AM
    Sky
    Brandon
    Redlands/Yucaipa
    Thank you... I meant to say that's not over $300
  4. Oct 18, 2014 at 1:22 AM
    Sky
    Brandon
    Redlands/Yucaipa
    next question is what Thickness should i go with?
  5. Oct 18, 2014 at 1:25 AM
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    are you machining your head or anything like that? are you looking to maintain your stock compression ratio?
  6. Oct 18, 2014 at 1:28 AM
    Sky
    Brandon
    Redlands/Yucaipa
    maintain stock... if i do anything... ill put a 4.6 tundra V8 in way down the road...lol
  7. Oct 18, 2014 at 1:33 AM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    Then you should go with stock thickness! I'm not sure what that is! But anything thicker would lower your compression ratio and you'd have less power, and the ability to run more boooooost! (making more power), but it doesn't look like that suits your situation!
