head installed and now have a p1300 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomahappy, Nov 8, 2010.
  1. Nov 8, 2010 at 10:04 PM
    tacomahappy
    tacomahappy [OP] Member
    mike
    Los Angeles, CA
    97 Tacoma 2.4 ltr extra cab
    I just changed my head after it was serviced with a valve job and resurface on 97 tacmoa 2.4 ltr. It took 5 minutes of cranking to get it started. I thought it was starving for fuel with a new filter and empty lines. I stopped and started it 4 times. When it was running it idled smooth. Now it will not start and my obd ll code reads P1300. Ok, when I lowered my timing gear and chain I turned the engine over by hand to clean the carbon off of the pistons. Later after installing the gear and chain back onto the intake cam the chain to gear mark was off by 5 teeth on the sprocket. I was told that if The #1 piston was at tdc and confirmed by the crank pulley, the cams both lined up on there marks, and the distributer was installed back lining up at #1 plug, then the chain shouldn’t matter. I don’t think that is the problem but it was in the back of my mind. Sticky listed p1300 as igniter circuit #1 under code problems. I’m stuck. What should I do now?
  2. Nov 9, 2010 at 9:11 AM
    tacomahappy
    mike
    Los Angeles, CA
    any help out there?
  3. Nov 9, 2010 at 8:22 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    compression test?
  4. Nov 9, 2010 at 8:34 PM
    tacomahappy
    mike
    Los Angeles, CA
    Ok, today I came across somthing weard. I did get it started again but it will only run with the OBD ll scanner connected. I think that it was also conected on the initial start up too. When it runs with the scanner connected it doesn't detect any codes. Sorry I didn't check compression.
  5. Nov 9, 2010 at 8:45 PM
    Fienoma
    Fienoma Well-Known Member
    Hieu
    New Mexcio
    2007 double cab Off road 4x4
    BHLM, In bed lights mod, K&N intake,OEM bed extender....more to come?
    Check your grounding. my cousin recently installed an intake manifold on his car and forgot to tighten down his ground wire. same thing happened to him. car only started with the scanner connected.
  6. Nov 9, 2010 at 9:03 PM
    jramuz
    jramuz Member
    I bought my tacoma and the previous owner had done a valve job and replaced the head, but told me that he was not able to set the timing belt marks. Can anyone advice or give me a link to the timing belt and cams marks on 95 tacoma. Its has a rought start, does not stay idle and no power. The check engine light is own and I dont know how to get the code from it. Any help will be greatly appreciated.
  7. Nov 9, 2010 at 9:15 PM
    Fienoma
    Hieu
    New Mexcio
    Usually when it comes to anything with timing and aligning i wouldn't mess with..take it to a professional
  8. Nov 9, 2010 at 9:53 PM
    tacomahappy
    mike
    Los Angeles, CA
    thanks, I will double check for the ground connections first thing tomorrow.
  9. Nov 9, 2010 at 10:13 PM
    tacomahappy
    mike
    Los Angeles, CA
    If you want to tackle the timing issue I suggest that you buy a service manual and read about timing chain replacement. I have to warn you that it's not for beginners. You will have to have some mechanic experience, tools, and time. About the codes, you will have to hook up a OBD code reader to the truck from inside the cab. The service manual will show where to hook it up also. I would also advise to check the compression to see if the valve job was done right. I checked my valves with gasoline for leaks before installing it. Good luck
  10. Nov 10, 2010 at 10:38 PM
    tacomahappy
    mike
    Los Angeles, CA
    :D
    :D
    Thanks, it was the ground.... firewall to engine.... Runs like a champ...
    I'm Tacoma Happy again!!!!!! :D:D:D:D:D:D
