HEAD LIGHT HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by M715kaiser, Feb 27, 2020.
  1. Feb 27, 2020 at 2:12 PM
    M715kaiser
    M715kaiser [OP] Member
    Just bought a new to me 2011 tacoma. Called dealer and headlight recall for the overheated bulbs to hot melt and cracking headlight assy expired . Were is best place to order aftermarket that are not 300bucks each . Any help and part numbers appreciated
  2. Feb 27, 2020 at 2:16 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome! Check out this thread for all things 2nd Gen Headlight, including info on the TSB and a link to the TSB with part numbers:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    OEM 2005-2011 smoked headlights:
    These are like the Pro lights, but came on select Sport models. These are the updated TSB version of the lights that do not have the melting DRL issue. TSB with additional part numbers is available here.
    Right: 81110-04210
    Left: 81150-04210
    Stock light on left, Smoked chrome Pro on right. 2012-2015 shown as example, part numbers above are the 2005-2011 version.
    Naveronski, Tigerian and TnShooter like this.
  3. Feb 27, 2020 at 2:47 PM
    M715kaiser
    I live in va i wonder if they would pass inspection since we have to get inspected once a year. Many thanks
  4. Feb 27, 2020 at 2:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I would think, since they are an OEM Light, they would pass inspection.
    You would need to adjust them, the direction for which are located in the link posted above.
  5. Feb 27, 2020 at 2:59 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Those look like 2nd gen headlights, oops my bad I read to slow. Damn old eyes.
  6. Feb 27, 2020 at 3:21 PM
    M715kaiser
    Good grief , anywere that they can be purchased for less than 200bucks each
  7. Feb 27, 2020 at 3:25 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    For new oem? Probably not. ebay and other similar sources will have knock offs, but don't expect oem quality for ebay prices.
  8. Feb 27, 2020 at 3:28 PM
    TnShooter
    Deogee
    STOCK
    If you are looking for a cheaper aftermarket option, maybe this will work?
    https://www.headlightsdepot.com/search/2011/toyota/tacoma
    I have no experience with them, but it may be an option?
    Skyway likes this.
  9. Feb 27, 2020 at 3:32 PM
    M715kaiser
    Oem apparently not that good either. From what im seeing.
  10. Feb 27, 2020 at 3:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    OEM are by far the best in terms of quality and performance. The early 2nd Gens had a design flaw that Toyota fixed for free to those that brought their trucks in, but that free replacement is now expired. The part numbers I linked are Toyota's TSB redesigned assemblies that do not have the melting DRL issue.
    TnShooter likes this.
  11. Feb 27, 2020 at 3:38 PM
    M715kaiser
    Thanks alot. I will def go the oem you supplied. I will also say that i have been on many different forums for different brand vehicles , this is so far the most respectful . Not even one smart remark to the newby. Many thanks.
    crashnburn80 and TnShooter like this.
  12. Feb 27, 2020 at 3:41 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is a good forum. If you check out the TSB link I provided, there are part numbers in there for the bright chrome replacements, rather than smoke chrome I linked. If you shop around by part number you can find the bright chrome for just a few dollars cheaper, though I think the smoked chrome is a nice subtle upgrade if swapping the assemblies.
  13. Feb 27, 2020 at 3:55 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Look at am-autoparts headlites come with 10yr garantee
