Head lights auto off
Discussion in 'Lighting' started by geochurchi, Jul 2, 2013.
  1. Jul 2, 2013 at 12:16 PM
    geochurchi
    geochurchi [OP] Active Member
    NH
    Tacoma
    Hi All,I have '12 Taco according to the OM the headlights should shut off automatically when the key is in the loc position and the driver side door is opened, this dose not happen, has anyone else noticed this?
    GC:confused:
  2. Jul 2, 2013 at 12:29 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    One thing I've noticed is the lights will not automatically shut off & the door window will still have power (for about 30 seconds) IF you open the door BEFORE shutting the truck off.
    If you shut off the truck & then open the door, the lights shut off and power windows are powerless.
    This is what I've noticed.
  3. Jul 2, 2013 at 12:29 PM
    CanisLupus
    CanisLupus Well-Known Member
    Ashburn | VA
    '11 DCSB 4WD / '13 Ninja 300 / '04 CRF 150F
    ^^^ This is how it's supposed to work OP. Lights auto shut off when you turn the truck off, then open the door.
  4. Jul 2, 2013 at 1:05 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    Right, so if you want your headlights to automatically shut off; Turn truck off, THEN open the door. They should shut off as soon as you open the driver's door (not sure about passenger doors).
  5. Jul 2, 2013 at 1:55 PM
    geochurchi
    NH
    Tacoma
    Problem solved,I recently installed marker lights and wired them into the headlight circuit the new lights are backfeeding the headlight circuit bypassing the auto off feature,I removed the fuse for the new lights and all is well.Does anyone have any idea where that timer might be located?
    Thanks:confused:
  6. Jul 4, 2013 at 2:17 PM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    Probably not a timer as it keys on the door. More likely the door switch is causing the headlight relay to drop out when door opens. Don't know where it is though.
    You might be able to hear it as the lights are turned on and off and on and locate the relay by sound.
  7. Jul 5, 2013 at 4:28 AM
    geochurchi
    NH
    Tacoma
    The problem seems to have solved itself, at least for now but I will try to locate that relay by playing with that door switch.
    Thanks
