Head Lights dimming when I press the brake pedal.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kingair84, Feb 25, 2016.
  1. Feb 25, 2016 at 9:12 AM
    Kingair84
    Kingair84 [OP] Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    I was just wondering if anyone else is having this issue. I have a 2016 TRD off road tacoma 6 speed MT. I have noticed since new when I press the brake pedal there is a noticeable light electronic click/clunk in the pedal. Then the headlights noticably dim. It happens no matter what amount of pressure I apply to the brake pedal. Its not the abs kicking in because it brakes work normally. I'll be taking it to the dealer but I don't want them to tell me it's normal because it seems like it should not be dimming the lights. I have done nothing to the electrical system or lights. Its all stock other than a skid plate and grill. Thanks in advance.
  2. Feb 25, 2016 at 9:16 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Definitely not normal, so take it to the dealer. If they try to pull that, then find another dealership to work with. There's a warranty for a reason, so use it!
  3. Feb 25, 2016 at 9:16 AM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Check your battery connections and your alternator. Make sure nothing is loose. You shouldn't be dimming your lights when pressing the brake.
  4. Feb 25, 2016 at 9:27 AM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    I don't know if it's related but I did notice that when my tuck is cold and I hold the brake pedal down the RPMs increase, release pedal and they go back down. It doesn't do it once it's warmed up. it's also a manual. If there is some type of increased engine load from the brake system that is not being compensated for in your truck(by increased RPMs) that may be why your headlights dim. Do you (or anyone else) see the RPMs go up when you hold the brake pedal down when your truck is first started?
  5. Feb 25, 2016 at 9:27 AM
    busticator
    busticator Well-Known Member
    FL
    2016 Tacoma SR5 DCSB
    CPS rev2
    Why do you need headlights to see if you are slowing down?
    Just kidding, yeah sounds like something to get fixed ASAP.
    doublethebass and Kingair84[OP] like this.
  6. Feb 25, 2016 at 9:50 AM
    Kingair84
    Wisconsin
    I will pay attention to this next time I start it up and let you know.
    shakerhood likes this.
  7. Feb 25, 2016 at 10:01 AM
    WRXChris
    WRXChris Member
    Colorado
    16 Tacoma TRD Sport AC 4x4 Manual BBP
    I've noticed the RPM increase when applying brakes on cold starts, 10F outiside. I think I remember seeing the headlights dim slightly when I hit the brakes while it was warming up. I usually have to scrape some ice, by the time I'm done with that the truck is warmed up enough and acts normal. It's a warm 26F today, I'll see if I notice anything weird.
  8. Feb 25, 2016 at 1:19 PM
    Kingair84
    Wisconsin
    Do any of you feel a slight electronic click or clunk in the brake pedal with a manual transmission. They are trying to tell me it's normal for a manual transmission. I refuse to believe that a brand new trucks head lights should dim when you use the brakes.
  9. Feb 25, 2016 at 1:54 PM
    WOTaco
    No. No feeling of anything through the brake pedal on my Taco only the RPM increase as mentioned. I actually notice that in my 2004 4Runner and often wondered if it was normal. It feels like the ABS is kicking in for a split second but it's not and it happens when I'm not even moving. As far as what the dealer told you, I call BS. Why would it be normal for a manual and not an auto? Aren't the brake systems basically the same?
    Just out of curiosity, do you have the tow package? If so, you have a higher output alternator than trucks without tow package. I have tow package on mine.
  10. Feb 25, 2016 at 2:00 PM
    Kingair84
    Wisconsin
    That's the exact feeling I was trying to describe! And yes I have the tow package and I thought the same thing it's the same brake system as the auto. They are trying to say it's when shifting the engine will bog down and the lights will flicker like on all manual transmission vehicles when the engine bogs down if you shift shitty. That's not what it is though. Its directly related to pressing the brake pedal. I refused this explanation they are on the phone with a TOYOTA electrical engineer now.
  11. Feb 25, 2016 at 2:14 PM
    Kingair84
    Wisconsin
    Well so far it's supposed to be "normal" which I doubt. I just can't see how the lights dimming can be normal operation. I'll have to try another 2016 MT to see if it does it as well.
  12. Feb 25, 2016 at 2:27 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    ^^ This is exactly how my truck behaves at cold start up.
    I too feel the slight electronic click/clunk when applying the brakes. I think these two "symptoms" are directly related to the type of brake booster we have on the OR. I read in another thread that it is electric rather than vacuum, and if you look under your hood, you won't see the big assed can behind your master cylinder that is typical in a vacuum system.
    As far as the lights dimming, I honestly haven't noticed that.
    You just know I'll be watching for it now, thanks for that! ;)
    Frank
  13. Feb 25, 2016 at 2:29 PM
    Kingair84
    Wisconsin
    Oh great thanks that helps a lot! Let me know about your lights.
  14. Feb 25, 2016 at 2:35 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    I'm no electrical engineer, but I've seen this happen plenty of times on vehicles, Ford in particular. Most of the time there is a ground fault somewhere.
    Could be same reason for the rpm gain, additional load on the alternator is causing it to add a little speed to boost the output.
  15. Feb 25, 2016 at 3:14 PM
    MOC221_
    Frank
    OK, I just checked out the headlight/brake thing - Here's the skinny:
    With the truck idling (hot), the lights dim just slightly for about .5 to 1.5 seconds when depressing the brake pedal. I had the door open and was listening for a compressor/pump like sound (brake booster) and sure enough - you can just barely hear it with all the engine noise. The lights dimming and then returning to normal directly followed this sound. I also saw the same thing in the dome light ('cause I had the door open!). If you hold the brakes, the lights just dim once.. presumably because you've built up enough pressure in the brake lines etc.
    Then, I killed the engine and tried it again - no brake booster this time, and thus no dimming.
    To sum up, I think IMHO we're both good and our trucks are behaving normally. Either that or we have the exact same problem
    Frank
  16. Feb 25, 2016 at 9:30 PM
    Kingair84
    Wisconsin
    Awesome! Thank you so much! I couldn't find another MT to try it on and that's exactly what mine does as well.
  17. Feb 25, 2016 at 9:42 PM
    WRXChris
    WRXChris Member
    Colorado
    I drove mine this evening, and it does the same thing MOC211 described, so it's not limited to the OR. When driving, if you stay in gear when applying the brakes the alternator seems to produce enough amperage to prevent the dimming, however if you shift to neutral and then apply the brakes, the lights will dim. I agree that it is normal behavior, I'm not worried about it.
  18. Dec 28, 2018 at 12:26 PM
    Zoop
    Zoop Well-Known Member
    Anybody that's having this happen also have the screen between their dash gauges flash brighter for a second? I'm getting the exact same symptoms + brightened dash screen. Checked grounds, sanded + dialectic and it did not remedy. (Dash cluster light turned down to either zero or +2)
  19. Dec 28, 2018 at 12:28 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I get this increase in RPMs when it’s cold, but that’s the truck trying to warm up.
    The headlights shouldn’t be dimming. That’s an electrical issue
  20. Dec 28, 2018 at 12:56 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    You need to check your charge voltage at the battery and see what it is reading when this is happening. Low alternator output at idle is a culprit of this sort of problem.
