Head Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buckaroo1993, Jul 3, 2018.
  1. Jul 3, 2018 at 4:05 PM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    What is the brightest/whitest HALOGEN head light bulb available for our trucks?
  2. Jul 3, 2018 at 4:17 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I think 8000k lumens is as bright as you can get before it starts turning blue. But if you want good bright lights i would look into retrofitting for projectors
  3. Jul 3, 2018 at 4:18 PM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    I use Piaa Xtreme white bulbs. I've had them in a while. Happy with them. Also, since you are in a spending mood I would also replace the headlight housing with new ones if your OEM ones are yellowed.
    Smash8ight likes this.
  4. Jul 3, 2018 at 4:19 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    6000k is slight blue
    8000k is very blue
    4300k is white with a tiny bit of yellow
    That said.... the higher the KELVIN, the DIMMER the output.
    "K" stands for KELVIN...... thats it. Not lumen, not lux, not banana.... KELVIN
  5. Jul 3, 2018 at 4:24 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  6. Jul 3, 2018 at 4:46 PM
    Smash8ight
    Smash8ight Well-Known Member
    04 trd
    Bone stock
    I like bananas......and bright head lights.
    inwood customs likes this.
  7. Jul 3, 2018 at 4:48 PM
    Smash8ight
    04 trd
    Bone stock
    I've seen the convertions...while really nice upgrade.....the investment is steep...ill stick with halogen....
  8. Jul 3, 2018 at 5:18 PM
    Smash8ight
    04 trd
    Bone stock
    Were abouts can I find some of these?
  9. Jul 3, 2018 at 8:50 PM
    Glamisman
    Glamisman Well-Known Member
  10. Jul 4, 2018 at 10:41 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
  11. Jul 4, 2018 at 12:41 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Same bulb though so yes it will. Plus it's beneficial to upgrade to a custom relay harness.
    The Driver[QUOTED] likes this.
  12. Jul 5, 2018 at 6:44 AM
    The Driver
    Raph
    I stand corrected!
  13. Jul 5, 2018 at 10:48 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I have these https://www.amazon.com/Philips-9003CVB2-CrystalVision-Upgrade-Headlight/dp/B00SQU0YG6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1530812820&vehicle=2001-76-1037-998--53--7-3995--8-1-2282--6-0&sr=1-1&ymm=2001%3Atoyota%3Atacoma&dpID=41bdPxsoQpL&preST=_SY300_QL70_&dpSrc=srch and really like them. They actually seem to output more light than the OEMs. If you combine it with a headlight polishing, if yours need it, and they have a nice tiny bit of blue visible in the reflector which looks nice. I also put them in my Sequoia, but due to the refletor design they don't seem to have the blue visible in the relfectors as much as my Tacoma does. Highly recommended
  14. Jul 5, 2018 at 10:54 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I put a set of the Silverstars in mine. The light is whiter than stock, but in my opinion, not better. My lenses are clear, but the insides are starting to yellow and there is "crazing" along the focal points from age. I would get brand-new units (I plan to) and put a set of Silverstars into them.
  15. Jul 5, 2018 at 10:57 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I will never run Silverstars again. I do like the bulbs, but they are stupid expensive and burn out very quickly. I can't spend $70 on bulbs for them to maybe last a year. There are better options. Just look on the back of the packaging. They even show you that they don't last long compared to their other products.
    Ridgerunner likes this.
  16. Jul 5, 2018 at 10:59 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I've had good experiences with Philips and Osram. Not so much with Sylvania Silverstar. Have to be careful not to get knockoff bulbs made in china. If the bulb is made in Germany then you're good to go.
  17. Jul 5, 2018 at 11:00 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I barely use my truck anymore and even less frequently drive it at night. I installed these SSs about 6 years ago and probably used the headlights only a couple dozen times so I believe you. Good thing I saved the stock bulbs.
