Head lights
Discussion in 'Lighting' started by Lrm2, Dec 2, 2022.
  1. Dec 2, 2022 at 11:23 AM
    Lrm2
    Lrm2 [OP] New Member
    Lenny
    2010 Tacoma
    I have had my 2010 tacoma for a couple of years. Have been through a couple sets of head lights in the past year and now need to replace another one. Any idea why they are going so fast?
  2. Dec 2, 2022 at 1:11 PM
    Tacospike
    Two Trucks
    What are you using to replace them?
    What going wrong with them?
  3. Dec 2, 2022 at 5:13 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Is there any moisture in your headlamp housings? Especially water pooling in the bottom of the lamp?
    Do you touch the bulbs glass when installing? If so you should clean the glass with isopropyl alcohol and a lint free rag, as the oils from your fingers can cause hhotspots on the glass, eventually leading to an envelope failure. Not necessarily the bulb exploding, but melting and losing its vacuum/xenon gas mixture.
    Also, what Specific bulbs have you purchased?
    Do you typically leave your headlamps switched on, so they are always on and also turned on when you first hit the ignition?
    Too Stroked likes this.
