Head scratchin electrical problems
Discussion in 'Technical Chat' started by Beau541, May 9, 2013.
  1. May 9, 2013 at 5:44 AM
    Beau541
    Beau541 [OP] Member
    Beau
    England
    2005 double Cab
    Plasti-Dipped badges, 40 series flow master, bilstien 5100 up front, 2.5" add-a-leaf in the back, 33" BFG Mud terrain T/A KM2 tires with 17" Ultra Crushers.
    About 9 months ago I put a new battery in my 05 tacoma. Since then I deployed for 8 months and found out that while deployed my truck wouldn't start. My wife would start it using a jump box and let it run but then it wouldn't start again. I thought it was the alternator but once it was idling it wouldn't die and the lights wouldn't dim. However, the alternator is running really hot and the pulley was pretty rusted. I was messing around with it today and found a 30 amp draw, which doesn't make sense because that's a lot of power to just disappear. The battery output is roughly 13 volts or less. I would drive it around after jumping it, turn it off and try to start it again and it wouldn't even click. I pulled a bunch of fuses and cleaned up some stuff and tried it and it turns over like theres no problem. I let it sit for about 16 hours and it started again but I'm sure it will act up again. I'm completely electrically stupid and I'm out of ideas. Any suggestions would be appreciated.
  2. May 9, 2013 at 6:00 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Do your lights come on when it fails to start or is it completely dead?
  3. May 9, 2013 at 6:07 AM
    Beau541
    Beau541 [OP] Member
    Beau
    England
    2005 double Cab
    It's completely dead. Sometimes the starter won't even click.
  4. May 9, 2013 at 6:09 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    If you were to turn on the light,would it come on ?
  5. May 9, 2013 at 6:12 AM
    Beau541
    Beau541 [OP] Member
    Beau
    England
    2005 double Cab
    Nope, nothin would come on. No headlights, instrument lights, nothin.
  6. May 9, 2013 at 6:16 AM
    97Blk_one
    Memfrica
    not so low
    Have you got your battery tested out at your local AutoZone? It's shouldn't the battery,because you just got it 9 months...
  7. May 9, 2013 at 6:23 AM
    Beau541
    Beau541 [OP] Member
    Beau
    England
    2005 double Cab
    No I haven't. I'll have to find a place in England. I thought about doin that but I figured its brand new so that couldn't be it.
  8. May 9, 2013 at 8:08 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Static voltage is one measurement but a load test is going to tell you what the battery is doing when you flip the ignition key on.
    I'm going to say it's probably your connections since you can put a jump box on it and start. Eliminates all the wiring to/from. If it's a serviceable type you can pop the caps and check to make sure the electrolyte is at the proper level (unlikely but it happens) and make sure the battery connections are tight with no corrosion (much more likely, especially with a newly installed battery).
  9. May 9, 2013 at 10:20 AM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    Put your amp meter on it and watch the amp (not the voltage)usage and pull the fuses and to find out where your short/usage is going. You will have to disconnect the battery and put the meter in line on the hot side to find the draw.
  10. May 9, 2013 at 11:09 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Sounds to me like the battery is shot. You most likely let it drain too much. Replace your battery and I'm sure it will be fine. Any time you leave a vehicle sit for a long period of time you need a battery tender or to just remove the battery.
  11. May 9, 2013 at 3:32 PM
    Beau541
    Beau541 [OP] Member
    Beau
    England
    2005 double Cab
    Thanks everyone for the input. I'm going to try all your suggestions. Then I'll start throwing parts at it. Thanks everyone.
  12. May 9, 2013 at 3:38 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    YEP--BATTERY! Should be under waranty! Get another. It should be FREE
  13. May 9, 2013 at 10:20 PM
    TheMontanian
    TheMontanian Member
    Ben
    Missoula MT
    02 prerunner Dbl-Cab
    OME add a leaf. Toyota MT open country's. Grille and little shit
    Honestly i had a chevy do the same thing (run sometimes & B completely dead others) it wasnt the battery but instead the connection when i took it off retightened with a washer on it the problem never happened again. So basically double check your connections if ya havent already!
  14. May 11, 2013 at 3:10 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Lead acid batteries are perishable, especially wet batteries in hot weather. If you battery has not been recharged in eight months, the most likely cause is sulfation from the natural self-discharge of the battery and the vehicle's parasitic load. For more information, please see Section 16 in the Car and Deep Cycle Battery FAQ at www.batteryfaq.org.
  15. May 22, 2013 at 3:53 PM
    Beau541
    Beau541 [OP] Member
    Beau
    England
    2005 double Cab
    Thanks everyone for the input. I ended up cleaning all the contacts, and put that sumbitch on a trickle charger for like 3 days. Haven't had any problems yet.
