Head Unit/Dash Ground Point - Gen 2
Discussion in 'Audio & Video' started by wizzard, Aug 31, 2010.
  1. Aug 31, 2010 at 3:50 PM
    wizzard
    wizzard [OP] That was now...this is then
    Just south of the middle of nowhere, MS
    2016 TRD Off-Road BBP Access Cab
    I'm in the middle of installing a head unit (x920BT) and am looking for a ground screw to utilize. There is an awful lot of plastic back there, so what are y'all using for the ground screw?
  2. Aug 31, 2010 at 4:02 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    i soldered an extra bit of wire to the end of my ground and used a big bolt that sits behind a panel separating the glove box and airbag area
  3. Aug 31, 2010 at 5:53 PM
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    Yeah I added on about 4 ft of wire and ran it down past the glove compartment to a screw as well....couldn't find any that were close.
  4. Aug 31, 2010 at 5:58 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Why do you need to bolt the ground? I just installed a stereo in my truck and just wired everything into the factory harness which includes a ground. The radio I got had a C connector on the ground too, but I just cut it off and spliced it into the harness I bought to use the factory connectors. My stereo works awesome!! I've also heard that long ground wires can create alternator whine coming through the speaker.
  5. Sep 1, 2010 at 4:32 AM
    Endurozw
    Zach
    Birmingham, Alabama
    Hmmm no issues here and I did consider just using the stock grounding point but after doing the bypass mod I felt a bit nervous with four ground wires running back and forth....wanted a good solid ground point to rely on.
  6. Sep 1, 2010 at 8:01 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I did the bypass on my Eclipse and soldered both ground wires to the ground in the harness. No noise or issues for me. My system is so quiet you could hear a mouse fart.
  7. Sep 1, 2010 at 8:07 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    used the harness as well, even for the bypass....no issues.
  8. Sep 1, 2010 at 8:12 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I just drilled a hole in the metal bar behind it and used a self tapping metal screw to secure the ground.
  9. Sep 1, 2010 at 9:16 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    i used the existing ground screw in the drivers kick panel.
  10. Sep 2, 2010 at 3:22 PM
    craigFLA
    craigFLA Well-Known Member
    Ft. Lauderdale, Florida
    Tacoma TRD Sport Pkg.#1, XSP Package
    Leather, 20" rims, Borla cat-back exhaust, running boards, back up camera/3" screen in rear view mirror, carbon fiber interior trim. Tow Package. MODS: URD intake BHLM. Tinted tails & 3rd brake light Fog Light mod. 5pc Grill Craft (High Gloss Black powder-coat) T-Rex eye-lids AVS Wind Deflectors 3M Window Tint 15 front/30 rear OBX Sports Pedals Viper 5901 / remote start Pioneer AVIC F90BT-NAV Hybrid L8's in doors, L4's and Dynaudio MD102 tweets in custom kicks, morel rear-fill, JL TW5-13" sub, JBL MS-8, 2@Tru B475, Tru 4.65, PPI a600.2, PPI 456 X-over, Raamat BX2 and ensolite. relocated rear seats 3/4" Retrax cover electric dual "dead-bolt-lock" electric tailgate lock. electric Dynalock for Retrax Cover/custom fabricated case. kinetik second battery/power-gate isolation. Powerslot Cryogenic rotors, Hawks HPS Pads, SS lines,painted calipers&drums FULL trans flush mod OE Denso plugs
    Same here...no issues whatsoever.
