Head unit is dim
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Oct 7, 2021.
  1. Oct 7, 2021 at 4:42 PM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I've noticed lately when I turn on the 'running lights' during dusk type hours the
    head unit illumination gets dim. If I turn off the 'running lights' or fully turn on
    the headlights it gets bright. Backing off again to the 'running lights' it goes dim
    again. Today, while dim, it went bright again after a bit of a turn. Odd. Anybody
    seen anything like this?
  2. Oct 7, 2021 at 5:01 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Did you go under an overpass? There is an ambient light sensor at the front, right of the dash. Try covering it for a few minutes to see what effect it may have on your lights.
  3. Oct 7, 2021 at 5:19 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The dash dims when the head lights are on. There is a setting in the head unit to disable it. I think it is called “daylight mode”. Stupid design IMHO.
    Coyote501 and boston23 like this.
  4. Oct 7, 2021 at 5:21 PM
    gudujarlson
    Minnesota
    Is the ambient light sensor new in 2021? I do not think I have one on my 2020
  5. Oct 7, 2021 at 5:26 PM
    2021SR5V64WD
    I wondered if it was some ambient light setting - or some sensor I could turn off.
    To the manual I go...
  6. Oct 7, 2021 at 5:34 PM
    CT Yankee
    CT
    Have you tried looking on the dash, or in the Owner's Manual (OM)? It's called 'Headlight Control Sensor' in my OM but you won't find it in the index. Review the headlight section of your OM carefully.
  7. Oct 7, 2021 at 5:46 PM
    JSmith501
    JSmith501 Well-Known Member
    San Antonio, TX
    2017 Off Road 4x4
    My 2017 has the sensor, so yours should too. It's so damn annoying while driving under a bunch of overpasses.
  8. Oct 7, 2021 at 5:53 PM
    gudujarlson
    Minnesota
    If I have an ambient light sensor, it is useless when the headlights are on during the daytime. I've never noticed anything when driving under overpasses, but I definitely notice that I can barely read my display when driving with the headlights on during the daytime. This is happens when driving in low light weather where the lights are on to be seen rather to see.
