head unit problem
Discussion in 'Audio & Video' started by 07TacoRidah, Mar 27, 2011.
  1. Mar 27, 2011 at 5:53 AM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    I got around to installing my new h.u. (it's actually an old h.u., bought it a LONG while back and never got around to installing it). Not sure about the warranty either, most likely already expired. My problem is that NONE of the RCA outputs in the back give out sound. NONE. I have tried several times and nothing. I am looking for a budget, tight fit, maximum usage overall fix.
    Basically looking for something to allow me to connect my amps (only 2, one for bass and the other for mids/highs up front only) yet be able to control both with one remote.
  2. Mar 27, 2011 at 7:20 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    My first thought is to check the manual to see if there is a setting to enable or disable the outputs. I know many have these in the settings section for the rear/sub out.
  3. Mar 27, 2011 at 7:41 AM
    07TacoRidah
    I have 3 sets of RCAs in the back, plugged into ea. individually and still nothing. I get sound through it normally but not through the RCAs.
  4. Mar 27, 2011 at 7:47 AM
    07TacoRidah
  5. Mar 27, 2011 at 7:48 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    blown outputs?
    What if it's just you amps not working? blown fuses? Bad connections?
  6. Mar 27, 2011 at 7:48 AM
    07TacoRidah
    everything else works fine, usb plugged in and read, cd, mp3's, etc. work as well as audio adjustments.
  7. Mar 27, 2011 at 7:49 AM
    McJosh
    Josh
    Chandler
  8. Mar 27, 2011 at 7:49 AM
    07TacoRidah
    nope, I know my amps were working fine period because before I installed this I had them wired to my OE h.u.
  9. Mar 27, 2011 at 7:50 AM
    McJosh
    Josh
    Chandler
  10. Mar 27, 2011 at 7:50 AM
    07TacoRidah
    no and I know, did a quick search only looked for pictures for the front/back of h.u. to get an idea of what it looks like as well as features ... physical that is.
  11. Mar 27, 2011 at 7:50 AM
    McJosh
    Josh
    Chandler
    pics of your truck? and bikes?
  12. Mar 27, 2011 at 7:53 AM
    07TacoRidah
    I have yet to run into a Pioneer that has that or has not had audio come out the back rca(s) via setting or what have you. all of the h.u.'s I have gotten all allow me to connect via rca without problems or usage of settings to hear sound, to adjust yes. I find that odd that everything else works fine except the rcas. :mad::(
  13. Mar 27, 2011 at 7:55 AM
    07TacoRidah
    pix of truck are floating around here, mainly in the "Street Trucks" forum on here. as for my bikes, they are both taken apart, have to clean and reconfigure build (nothing fancy, change of colors, additions, leaving room for pay).
  14. Mar 27, 2011 at 12:35 PM
    07TacoRidah
  15. Mar 27, 2011 at 12:40 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Have you checked the speaker wires to see if you are getting anything? As said above, maybe a setting to turn the pre-outs on/off. :notsure:
  16. Mar 27, 2011 at 4:37 PM
    07TacoRidah
    went through the manual and tried the settings, still no sound. :(
  17. Mar 27, 2011 at 5:06 PM
    TacoDawgfan
    Georgia
    So you cant get anything from the amp in the hu either? Or does it have an amp built in? Just trying to narrow down if it is putting out any sound or if it is in the pre outs.
  18. Mar 27, 2011 at 9:20 PM
    McJosh
    Josh
    Chandler
    time for a new stereo. :(
  19. Mar 27, 2011 at 10:54 PM
    07TacoRidah
    I get audio from the h.u. connection fine. the pre-outs won't work. find it odd that not one of them works, is it common for the pre-outs to blow out? I have yet to have a deck where the pre-outs did not work (even when I have gotten used decks, at most the faceplate stopped showing the digital stuff).
    finally got the dash kit and this happens :(
  20. Mar 28, 2011 at 7:57 AM
    07TacoRidah
    well after thinking a lot and assessing my funds lol. I am going to go with a simple eq. which I can place in the storage cubby of my dash kit. still have the old LOC that I was using, looks more beat than it did when I first installed it :(
