Head Unit Upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimCali75, Sep 24, 2023.
  1. Nov 1, 2023 at 7:55 AM
    #61
    Mtbkrguy
    Mtbkrguy Well-Known Member
    2016 Tacoma TRD Sport 4x4 Double-cab
  2. Nov 1, 2023 at 11:24 AM
    #62
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    Yes, that makes sense it would use the same DAC. I upload WAV files from my hard drive to a USB and plug it into my USB port. That's my preferred method of listening.
    Stevie17 likes this.
  3. Nov 4, 2023 at 9:13 AM
    #63
    Kevin45036
    Kevin45036 Member
    2023 Tacoma SR
    Got the XAV-9000ES from trail grid pro. I noticed that the number of cables that the stock 7” Entune had plugged in outnumber what was sent to connect to the plugs on the back of the headunit kit, then an extra 2 pin cable that doesn’t have a match on the Toyota.
    Some are explainable, I didn’t get the Siriusxm tuner. There is one that was ignored. I watched the video on trail grid pro, and it basically showed them hook everything up that matched. In my 2023 SR it has a 30 pin and 2 28 pin connectors, as well as the smaller black connector (12 pin? ) that is the factory wiring harness. It does appear to matter which of the 28 pins are used. When I used the Black 28 pin connector from the truck to the it doesn’t work. When I used the Gray 28 pin connector from the truck to the harness, it powers up and works. I’m presuming that the “extra” black connector is for something that my kit isn’t utilizing. My stock radio does have wiring for options that my SR doesn’t have for example GPS. It is wired for a GPS antenna.
    Anyone else have a similar experience or know what the extra 28 pin connector is for ?
  4. Nov 4, 2023 at 10:09 PM
    #64
    Sandthemall
    Sandamal
    2023 TRD OR MT
    Yes, I had the exact same experience. I also used the wrong 28 pin connector initially. And a quick switch to the other connector solved the issue.
  5. Nov 21, 2023 at 9:42 PM
    #65
    Taconetti
    Taconetti Member
    Tony
    23 Lunar Rock TRD OR
    Have you had any issues with this head unit. Trying to decide between the Alpine halo 509 or this Sony. Thoughts? Issues? Trouble? Pure audio heaven?
    Choctaw Taco likes this.
  6. Nov 22, 2023 at 3:41 AM
    #66
    Bails
    Bails Well-Known Member
    Tampa, Florida
    2023 TRD Sport 2WD
    For whats its worth no issues or loss of stock controls with the Kenwood dmx1057xr. BUT if I were to do it over again I would not have purchased this unit as it is way over my tech. needs as far as audio controls..
  7. Nov 22, 2023 at 8:28 AM
    #67
    Sandthemall
    Sandamal
    2023 TRD OR MT
    What about the blind spot monitor on the mirrors? Do those work with Kenwood HUs?
  8. Nov 22, 2023 at 4:15 PM
    #68
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    I have a TRD Sport with Tech. Package, all work. Got everything from Crutchfield, I did not do the install I had a professional put it in but I'm sure some of you guys can do your own...
  9. Nov 27, 2023 at 6:09 PM
    #69
    StinkFu
    StinkFu Well-Known Member
    Pacific Northwest
    2022 Tacoma TRD Pro MT
    AJT Design Tacoma 4x4 Knob AJT Design Tacoma Climate Rings AJT Design Tacoma Door Handle Covers All-Pro Off-Road HD Rock Sliders Alu-Cab Tilting Fridge Slide Aluminum Radio Knobs Android Auto Cable ARB Twin Air Compressor AWE 0FG Exhaust with BashGuard - No Tips Badland Jack Mounts Badland Off-Road Jack Baja Design Rock Lights / Scene Pods Black Door Handle Covers Bolton Velocity Off-Road Kit Cali Raised AC Drip Relocation Cali Raised Center Console Molle Panels Cascadia 4x4 45W Panels & Controller Ceramic Coating CourseMS Phone Mount Desert Does It Seat Blocks & Panel Diode Dynamics Ditch Lights Diode Dynamics Stealth Light Bar Kit Dual Circuit Breaker Battery Tie-Down Expedition Essentials Panel Bracket Factor 55 HitchLink Flag Stickers Glove Box Letter Inserts GloveBox Organizer Hella Supertone Horn Kit Icon 1.5 Inch Lift Rear Expansion Pack Interior LED Light Kit Interstate AGM 24F Battery KC Hilites Under Hood Light Krazy Beaver Shovel and Cover License Plate Frames Magnuson Supercharger MAXTRAX Xtreme MAXTRAX Xtreme Mounting Pin Meso Customs Gasshole Meso Customs Vent Ring Kit MESO Overhead HexRack - Sunroof Mishimoto Radiator MMRAD-TAC-16 Nilight 3PCS 60 Inch Bed Light Strip Nitto Ridge Grapplers 285/70R17 Quick Charge 3.0 Dual Charger Socket RedArc Dual Input + 40 Amp Fuse Kit Rhino Rack Stow It Utility Holder Rhino Rack Stow It Utility Holder Rhino Sunseeker 2.0m Awning Rhino USA D Ring Shackles Rhino USA Trailer Hitch Lock RSI SmartCap Evo Sport RSI SmartCap Platform Rack SDHQ Battery Terminal Kit Seven Sparta Grill Led Lights Shift Knob Adapter SmartCap EVO Security Screen - v2 Smartcap MOLLE Panel Steering Wheel Cover Steering Wheel Emblem SumoSprings Front SumoSprings Rear Supreme Suspensions Front Tow Hooks Switch-Pros 9100 Switch-Pros Power Tray Wiring Bundle Tacoma Door Clean Up Kit Tacoma Door Sills Tacoma Lifestyle Sequential Turn Signals Tacoma Tailgate Inserts Tail Gater Tire Table Total Chaos Bed Stiffeners Toyota Cargo Net Toyota TRD Pro Shift Knob TRD PRO 17 Matte Black Alloy Wheels TRD PRO CAI Box & Accelerator TruckVault - Utility Height Uptop Alpha Rack - 38" Extreme LEDs Uptop TracMOUNT Vinyl Letter Decals for Tailgate Handle Vinyl Letter Decals TRD Pro Bedside Vinyl Letter Decals TRD PRO Grille VLEDS Dual Output Front Footwell Kit VLEDS VTAILS Taillight Conversion Kit WeatherTech Bug Deflector WeatherTech Rain Guards Wescott Tacoma Fox TRD PRO Lift Kit
    You were able to retain your Sirius functionality as well with the DMX1057XR? Thinking of doing the same.
  10. Dec 15, 2023 at 5:06 PM
    #70
    Sandthemall
    Sandamal
    2023 TRD OR MT
    Just a quick update about my Sony XAV-9000ES:
    Sony issued a software update for this unit. I tethered it to my phone and did the update. The message at the end mentioned that the updates may require several start ups to complete. I didn't quite understand what this meant. Well after a few days now, my USB connection recognition issue is resolved. Previous to this update, I would need to insert my USB stick (for my hi res WAV files) multiple times for the HU to recognize it. This was very frustrating to me because I bought this Sony head unit expressly for the excellent DAC chip (32-bit ESS DAC). Trail Grid Pro were very responsive and allowed me to return it for a full refund or exchange. I elected to wait it out and see what the update would do. After completing the update, nothing seemed to change at all.
    Today I started the car and it worked...ran some errands and each time I started the truck up...the USB stick was recognized! The Sony XAV-9000ES has all the features of the 9500ES but without the big screen...it's low-key. Now if I can get the Maestro to recognize the blind spot monitor on the side view mirrors, everything will be 100% functional compared to OEM.
    I noticed the software update for the XAV-9500ES came out few days prior to mine. For those of you with that unit, I'd like to hear your experiences with this issue. Did the update solve it?
    I need to say: Listening to big music files on a USB stick is stunning compared to XM radio or Bluetooth. No comparison.
    Choctaw Taco and StinkFu like this.
  11. Dec 15, 2023 at 6:17 PM
    #71
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I ordered the Sony AX6000 from Trail Grid Pro for my 2017. I chose this model as I only have one factory camera and didn’t want to add another camera. A huge difference over my factory JBL. CarPlay works great. I ran the Sony mic to the factory overhead location. Merry Christmas to me. I wish I would have done this sooner.
    Sandthemall likes this.
  12. Dec 29, 2024 at 7:58 PM
    #72
    JimCali75
    JimCali75 [OP] Well-Known Member
    James
    2023 White Tacoma OR MT Premium
    I realize this thread is a year old. Has anyone with floating screens experienced bad vibrations while wheeling? Especially washboard roads? I mean everything shakes loose with enough miles on washboard but I can imagine some of the larger screens might be pretty bad.
