Headache Rack/Rooftop Basket Combo
Discussion in 'Garage / Workshop' started by clarktom6, Apr 23, 2014.
  1. Apr 23, 2014 at 11:02 AM
    clarktom6
    clarktom6 [OP] Member
    OR
    '13 Tacoma DCSB 4x4 TRD Off-Road
    All-Pro Sliders OME 2.5" Coilovers w/ Top Plate Spacer Dakars w/ D29XL 285/75/r16 Goodyear Wrangler Duratracs Custom Headache Rack w/ Hella Black Magic 500's and outboard work lights
    I've been designing a headache rack with a rooftop basket attached (not sure if i want to weld rack or bolt it on for removal) and wanted to see if anyone had any input as to design flaws or additions. I plan on putting gussets where the rack and basket meet up. I only plan on using it for a camping gear/ATV riding gear, and a cooler. Curious to see what you all think. Also, plan on doing light tabs near wind deflector.
  2. Apr 23, 2014 at 11:09 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Interesting concept
  3. Apr 23, 2014 at 11:18 AM
    clarktom6
    OR
    Attached wrong file....
  4. Apr 23, 2014 at 11:20 AM
    OZ-T
    Peter North
    British Columbia
    Same as I saw the first time
    Have you considered running a top rail the length of the bed for tie down points ?
  5. Apr 23, 2014 at 11:20 AM
    clarktom6
    OR
    I need extra storage for when i load the ATV and Dirtbike in the bed, so this is what I came up with.
  6. Apr 23, 2014 at 11:22 AM
    clarktom6
    OR
    It would get in the way of the Glidplate, brake and footpeg on my dirtbike. I only have an 1.5" clearance to the bed rail.
  7. Apr 23, 2014 at 11:23 AM
    OZ-T
    Peter North
    British Columbia
    Like this
  8. Apr 23, 2014 at 11:26 AM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    I would add a support here. Those corners will have lots of stress on them.
    HeadacheRackwithRooftopBasket_zps5df5d42_7b167a87df843e81ad555b73be272fbb44cac353.jpg
  9. Apr 23, 2014 at 11:27 AM
    clarktom6
    OR
    Not Sure if you can see the footpeg in that picture
  10. Apr 23, 2014 at 11:28 AM
    XJfella95
    XJfella95 Product Developer
    Brandon
    Reading Pennsylvania
    '08 Taco DCSB
    A Few
    looks strong. Your cantilevered transition between the rack and the basket should be strong enough to hold its own weight but for extra measure, i would tie it into the factory roof racks forward most mounting points. this will alleviate any bouncing when you load it up with a cooler.
    also, you're showing sq tube from the whole construction. I would opt to use flat bar behind the glass and angle iron in a heel up orientation for the base of the basket to save weight.
    just a few things i can see, otherwise its a good design. just heavy.
  11. Apr 23, 2014 at 11:35 AM
    clarktom6
    OR
    Thanks, I forgot to mention weight reduction in my original post.
  12. Apr 23, 2014 at 11:38 AM
    clarktom6
    OR
    You think this would be enough for the corners?
  13. Apr 23, 2014 at 11:43 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    My brother has a cheaply made ladder rack for his 1ton Ford LB that is like what you're describing Oz. For something tough to be made with that cross member would be very interesting to me. I also haul dirtbikes, OP, and I bet you could make the crossmember to be removable. Slide it out, load the bike, slide the beam back in. Bolts or quick pins.
  14. Apr 23, 2014 at 11:44 AM
    clarktom6
    OR
    Great idea...wouldn't take much either.
  15. Apr 23, 2014 at 12:47 PM
    OZ-T
    Peter North
    British Columbia
    The rear crossmember in that pic is removeable and nests against the front when not in use , I'll see if I have another pic
  16. Apr 23, 2014 at 12:52 PM
    OZ-T
    Peter North
    British Columbia
    You can see the rear crossmember sits in a pocket and secured by a removeable through pin and cotter , when disconnected it nests inside the front crossmember
  17. Apr 26, 2014 at 5:34 PM
    OZ-T
    Peter North
    British Columbia
    Came across this pic
  18. Apr 26, 2014 at 5:39 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    The roof rack they made on "trucks" was kind of what you're going for. Theirs wobbled more than I would want though, that's going to be kind of tough to get around with the cantilevered design I would think.
  19. May 26, 2014 at 5:46 PM
    LINCOLN45
    LINCOLN45 Well-Known Member
    john
    sac
    2014 TACOMA DCSB
    265/70/17 TOYO OC AT Bilstein 6112 Coil and Strut Combo Tacoma Stealth 32" LED SOS SKID PLATES AND SLIDERS RIGID LED FOG LIGHT UPGRADE
    so if you used something like the n fab or other roof rack mount to support the basket over the cab
  20. Nov 10, 2014 at 5:38 PM
    TacomaTruckParts
    TacomaTruckParts Well-Known Member
    Jesse
    San Gabriel
    OP, A few points not to be missed:
    Think twice before "connecting" a bed rack to a roof rack; If you do even mild off roading, there WILL be frame flex/twist. that is why the bed is separate from the cab, to allow for some movement. Bolting a bed/roof rack to roof mounts and bed mounts could cause damage somewhere..... at the weakest point of attachment.
    For the cantilever design to work and be strong, the wall thickness of the verticals, and the size of the "triangles" will play an important role. There are a couple different ways to do a cantilever type support.
    You are asking a lot from that type of design. Notice how true over-cab ladder racks are not bolted to the cab, but usually have a cantilever support for the over-cab section, and bolt only to the front and rear of the bed.... for the strength to carry the rated load capicity of the ladder rack.
    Jesse
