Headed to the obx this weekend
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccal, May 23, 2017.
  1. May 23, 2017 at 4:46 PM
    ccal
    ccal [OP] Well-Known Member
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    I'm headed to the OBX this weekend and plan on taking the truck onto the sand, any idea what tire pressure I should run so I don't get stuck out on the sand like a tard
  2. May 23, 2017 at 4:51 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I always go to 20, then let more out if it's too soft. How far away is the nearest air pump or do you have OBA?
  3. May 23, 2017 at 5:48 PM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    I have a plug in air compressor
    Chase8059 likes this.
  4. May 23, 2017 at 6:48 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    I usually run around 12 to 14psi on the beach. The lower you can go the better the traction. Just keep your speed low and don't make quick sharp turns.
    BrokenMech likes this.
  5. May 23, 2017 at 6:51 PM
    doorsidedown
    doorsidedown Well-Known Member
    what size tires?
  6. May 24, 2017 at 2:39 AM
    ccal
    carmen
    kirtland ohio
    2014 tacoma trd
    2.25 leveling kit
    265/75/16 bff ko2
  7. May 24, 2017 at 2:47 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    When I lived there i always ran about 12. Have fun an be safe
    ccal[OP] likes this.
  8. May 24, 2017 at 3:08 AM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Do you have to pay to get on Oregan Inlet? I always found 20 psi to be fine. One time I drove all the way to the point at Oregon Inlet, went to restart and realized I was still in 2 wheel drive. That 4Runner was awesome.
    MattCowsmasher likes this.
  9. May 24, 2017 at 3:11 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I usually run normal pressures there. Never had a problem.
  10. May 24, 2017 at 4:27 AM
    BrokenMech
    BrokenMech Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
    Was at OBX last week. Beautiful weather.
    Ran 18-20 psi and didn't have a problem.
    Have fun!
    ccal[OP] and MattCowsmasher like this.
  11. May 24, 2017 at 4:37 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I usually run 15-18 with my KO2s but 20 is probably sufficient. Tire makes a difference, stiffer tire(E rated) may need a little less, more toward 15. Just remember the lower you go the slower you need to keep your speed. Tires can heat up at low pressure. Have fun out there and welcome to NC.
    ccal[OP], MattCowsmasher and Coot83 like this.
  12. May 24, 2017 at 4:43 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I would run somewhere between 15-18 as well out there.
  13. May 24, 2017 at 4:46 AM
    Bannerman
    Johnson
    Charlotte, NC
    I should mention, it depends on the sand. Alot of the "ramps" or entrances to the beaches here are sugar sand, and since there are lots of idiots with their 2500s out there running 80 psi and then getting stuck, there are also lots of ruts. But once you get past that area you can prob switch to 2wd with the lower tire pressure.
  14. May 24, 2017 at 4:46 AM
    Cooktop86
    Cooktop86 Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    I had my old truck in OBX (Ram 1500). I aired the tires down to 20 psi. If I remember there is a little gas station about a half mile off the beach access that has an air pump.
  15. May 24, 2017 at 4:49 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    One thing I recommend if possible for the future is getting a viair air compressor. You would be surprised how many guys will be at each gas station filling up their tires when they leave the sand.
  16. May 24, 2017 at 5:13 AM
    Bannerman
    Johnson
    Charlotte, NC
  17. May 24, 2017 at 5:57 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    @ajohnson
  18. May 24, 2017 at 6:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  19. May 24, 2017 at 6:22 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Don't forget your mankini!!!
  20. May 24, 2017 at 6:28 AM
    firsttraxxx
    firsttraxxx Well-Known Member
    NoVA-LoCo
    2013 Baja TX
    Fox 2.5 front / JBA UCA 3” Fox 2.0 rear / Icon RXT Stg 1 3” BAMF rear bumper Some cool mods
    igno1tus, ccal[OP] and MattCowsmasher like this.
