HEADER QUESTIONS
Discussion in 'Performance and Tuning' started by DFPTaco, May 7, 2013.
  1. May 8, 2013 at 11:16 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    supercharge all things, then worry about the other stuff.
  2. May 8, 2013 at 11:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    No problem sir. For the general masses, they use the term back pressure. But without the true understanding of what it refers to. Thus it becomes easy to get a misconception of what is happening.
    I knew what you meant though. :thumbsup:
    I have heard that there is a place here trying to crack the factory ecu.
    I heard a while ago that some Aussies had. But I don't search AU forums regularly.
    There just isn't the mass desire by owners or aftermarket to try to unlock it. So that is basically why it remains as is unfortunately.
    If more Tacoma owners were interested in performance and trying to push the limits, the the story could be different.
  3. May 8, 2013 at 12:09 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    This is good advice based on sound principles.
    Consider that the very low rpm range in which you want the most torque, the engine is running far below the exhaust system's maximum flow capacity.
