header suggestion
Discussion in '4 Cylinder' started by hortona, Sep 6, 2014.
  1. Sep 6, 2014 at 8:47 AM
    hortona
    hortona [OP] Well-Known Member
    99 tacoma SR5 w/ 3rz-fe
    Has anyone gotten one of those pacesetter headers that are like 170 bucks for the toyota 3rz-fe 2.7. If so how was it and was it a simple bolt on. Peace out.:D:D:D:D:):):eek:
  2. Sep 6, 2014 at 11:51 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I put one on my '97 3rz a year ago and so far so good. Bolted right up. The gaskets that come with it are garbage though so I'd recommend at least buying some quality gaskets when you do the install. I reused the stock metal manifold gasket, and bought a copper 3 bolt collector gasket from summit racing for the header collector to down pipe, then bought a remflex for downpipe to cat. connection. Most people on here prefer the LCE header for a bit better quality and ceramic coating but at $400+ I took my chances with the cheap one especially since its my hunting/offroading rig and so far so good.
  3. Sep 7, 2014 at 11:02 AM
    hortona
    cool beans. I am confused in the picture they make it look like some sort of two peace. do you know what thats about
  4. Sep 7, 2014 at 1:29 PM
    vern650
    brandon
    hyrum, ut
    it is 2 pieces, the main header, then a down pipe/extension pipe that goes from the header collector down to the cat. The second section also houses the o2 sensor. Probably just to make a simpler install without requiring actual exhaust mods.
  5. Sep 7, 2014 at 1:41 PM
    hortona
    oh cool beans. so it comes with a down pipe.
  6. Sep 7, 2014 at 7:08 PM
    vern650
    brandon
    hyrum, ut
    comes with everything to bolt it in
  7. Jan 4, 2015 at 2:29 PM
    theduckbutter
    theduckbutter Well-Known Member
    2005 tacoma access cab 4x4
    350lb custome leaf bender bumper overkill
    Thinking of pacesetters headers for my 2005 tacoma while I have it apart.
    any more feedback since this thread was updated??
    Any advice other than dont trust the gaskets?
    I remember they used to have BISON header gaskets. lasted lifetime of the vehicle. Best header gaskets I have ever seen. Unfortunately they were made of asbestos and discontinued..
  8. Jan 4, 2015 at 2:39 PM
    theduckbutter
    Checked PaceSetters site an they dont list headers for tacomas past 2000.. :(
  9. Jan 5, 2015 at 5:49 PM
    pasotaco
    pasotaco Well-Known Member
    Central Coast, CA
    2013 4x4 Access Cab
    LCE headers, King 2.5 Coilovers w/ res, TC UCA's, King resi's in rear, Geared to 4.88, rear locker, Timbren Bump stops, All Pro Leafs, Carrier bearing drop kit, ARB onboard air,
  10. Jan 5, 2015 at 6:47 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I just did a lot of work to my 2014 4x4 (lift, wheels, tires...) and the LCE header along with the ProDryS filter were, BY FAR, the best mods I did. Made a big difference in the "pep" of the little 2.7 Now, it's no rocket ship, but it's noticeably better than it was. Money well spent.
  11. Jan 6, 2015 at 10:29 PM
    theduckbutter
    mine is a 2005.. not a lot of extra $$ right now for 450 dollar headers but i will probably do that before its overwith.. would be nice to do right now while i have everything pulled out.. four more bolts and timing cover coming off tomorrow. havent checked threads for turbos but i have always wanted to put a turbo on this motor.. soon i will do lce header though let me know what you think
  12. Jan 6, 2015 at 10:36 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
  13. Jan 7, 2015 at 9:01 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
  14. Jan 11, 2015 at 4:46 PM
    pasotaco
    Central Coast, CA
    2013 4x4 Access Cab
    I put my lce headers on today, went for a drive and am super happy with the performance gain. Definitely more power, easier to get up to highway speeds without having to drop into a lower gear, easier climbing hills in higher gears... This is noticeable with the stock muffler and pro-dry filter.
    Thinking about pulling the carbon filter out too...
  15. Jan 28, 2015 at 11:30 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I run a Pacesetter as a quick option to a cracked cast manifold. I wouldn't do it again either. Spend the coin on an LCE or even the OEM tubular manifold from the last of the 1st gen run. I put all new gaskets, as the PS ones are POS. I've had to replace the collector to extension gasket about once a year and I'm running the high end parts house gaskets. Just this last trip I made, which was about 2 hours, I developed a exhaust leak tick that can be heard when accelerating. Granted I've had it for about 3 years now and it was the cheaply painted version that I stripped and resprayed with high temp, it has held up to quite some abuse. High revs, slow speeds, and then cold water/mud. I'll keep running it until it cracks a weld or finally rusts through and then I'll probably get the LCE one.
    Anyone use the NWOR one?
  16. Jan 28, 2015 at 11:34 PM
    Yota64
    Yota64 Professional Threadjacker
    That is impressive. Almost hard to believe...
    Best performance where? Low/mid/top?
    Which LCE? Equal or Short?
  17. Jan 30, 2015 at 9:29 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Low end, its supposed to lower the torque peak in the rpm range
  18. Jan 30, 2015 at 9:36 PM
    Yota64
    Hmm. Interesting, thanks
  19. Feb 1, 2015 at 6:36 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    While this header may or may not improve performance, that dynograph is complete BS. Easiest way to spot an incorrect graph is to see if horsepower and torque lines cross at 5252rpm. This will happen on EVERY dyno, EVERY engine, EVERY day. (Hp=torque x RPM/5252)
    It also shows stock peak torque at 5,000 rpm and peak hp a little lower around 4,600rpm. Also impossible. Torque will never peak higher than HP. Because Math.
    Someone's kid at LCE made that on Paint. :)
  20. Feb 4, 2015 at 2:16 PM
    vern650
    brandon
    hyrum, ut
    my pacesetters still goin strong with no leaks at any joint and I've never retorqued any fastners and its had some pretty rough offroading over the last year and a half. Looks a bit rough though as appearantly I didn't cure the hi temp paint I put on it right and a bunch of it flaked off.
