Headers and exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by idahotaco06, Nov 25, 2017.
  1. Nov 26, 2017 at 7:29 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Thanks I need to look into these O2 simulators and stuff now. Where is a good source for the DT headers just order direct from DT?
  2. Nov 26, 2017 at 7:34 PM
    DEDAFLO670
    DEDAFLO670 Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    Urd racing you could also get the o2simulators An if I'm not mistaken you get a disount on the 02 sim when you purchase the headers from them
  3. Nov 26, 2017 at 7:34 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    The rasp isnt to bad only at about 4500rpms. I'll most likely stay with shortys if the torque gains aren't really that different
    10thMTNgrunt likes this.
  4. Nov 26, 2017 at 7:37 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Ive used urdusa.com
    U should get a mil discount... call them and mention that u heard they offer said discount.
    Honestly id call and hit extension 3 and speak to gadget first... i forgot the 02 simulators had issues with some newer trucks. Get his input on that before you drop coin. Run the mil discount question by him.
    Also get the crush washers he offers.
    Casper66[QUOTED] likes this.
  5. Nov 26, 2017 at 7:37 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Thanks I was just looking at the headers on the Dt web site
    inwood customs likes this.
  6. Nov 26, 2017 at 7:39 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Since when? o_O
    My Y-Pipe on my Taco is well behind the Transmission...
    My Headers, as expected, bolt onto the motor... they then dump into exhaust pipes, run through catalytic converters, through more exhaust pipe, and eventually reach the Y-Pipe, which then dumps into more exhaust pipe until it hits the muffler, then through more pipe, and then exits the pipe into the atmosphere.
  7. Nov 26, 2017 at 7:40 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Thanks it's going to be a bit as my job is kinda iffy right now I'm just trying to get my ducks in a row so to speak. I enjoyed the bennifits I got out of the LCE header on the 4cyl so looking at going this route when I can. And Thanks for the heads up on the discount
  8. Nov 26, 2017 at 7:42 PM
    inwood customs
    Dave
    Op made it sound like he thought this mbrp exhaust he wanted may not work with the headers.... the headers dont touch any off the shelf exhaust (catback) directly.
    If u want to split hairs, the exhaust starts at the exhaust valves
    Casper66 likes this.
  9. Nov 26, 2017 at 7:47 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    If you do URD Long Tubes - you'll have to delete your front set of Catalytic Converters (unless you have someone weld them back in someplace). This means you'll need the O2 Simulator (which should work on your 2006).
    Note however, that URD's headers are known to create some rasp in the exhaust that often pushes people to install a Resonator. Ask me how I know. ;)
    URD Long Tube Equal Length Headers
    https://youtu.be/vwbNaN-OVUk
    Before Headers, After Headers, After Resonator
    https://youtu.be/pAmZeDdhFLk
    617mike9c1 likes this.
  10. Nov 26, 2017 at 7:50 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Yes, exhaust does start at the exhaust valves.
    None of this explains why you're suggesting headers bolt to the Y-Pipe though.
  11. Nov 26, 2017 at 8:09 PM
    inwood customs
    Dave
    because, bolts?
    I dont understand the dilemma here
    https://youtu.be/kE8hCb94GD0
    Torspd likes this.
  12. Nov 26, 2017 at 8:09 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Yep I just looked at the DT and the URD headers and the long tubes delete the first set of cats so I'm going to have to see what will work here with inspections. We don't have emissions where I live so they may be ok
  13. Nov 26, 2017 at 8:15 PM
    inwood customs
    Dave
    correct, bye bye 1st set of cats.... This is why the rasp can increase. With a stock ypipe (which as I showed bolts to the headers lol) the rasp may not be as bad because the 2 cats on the stock ypipe act as tiny resonators.
  14. Nov 26, 2017 at 8:59 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's enough humor for one night. Carry on gents. :hattip:
  15. Nov 26, 2017 at 9:07 PM
    #35
    Barbietaco
    Barbietaco Tools are good
    Shane
    2006 Tacoma
    Sas swap with Dana 60 and GM 14 bolt rear on 42" Pitbulls
    If you plan to do a SAS setup don't get long tube headers as they don't fit. Just a heads up.
  16. Nov 26, 2017 at 9:08 PM
    #36
    inwood customs
    Dave
    :laugh:
  17. Nov 26, 2017 at 9:09 PM
    #37
    inwood customs
    Dave
    Didnt know that...
    All long tubes, or is it the bends in the urd?
  18. Nov 26, 2017 at 9:12 PM
    #38
    Barbietaco
    Shane
    2006 Tacoma
    As far as I've been able to find out all of them. The upper link goes right where the passenger side cat would be. Seen it with DT, Urd, etc. I settled with DT shorty headers and a custom exhaust.
  19. Nov 26, 2017 at 9:51 PM
    #39
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    I find it hilariously amusing you took the time to video the underside of your truck.
    So, out of respect for your time, I'll do the same.
    Here ya go:
    https://youtu.be/Z2bS6TOTyT0
    Please excuse the fact that my truck isn't spotless underneath. I go to places like Moab. ;) lol
  20. Nov 26, 2017 at 10:00 PM
    #40
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    That's some useful information right there actually. :thumbsup:
