Headers and Y Pipe Questions
Discussion in 'Performance and Tuning' started by TacomaGus, May 25, 2016.
  1. May 25, 2016 at 7:41 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    I currently have the JBA long tubes and have been thinking about replacing them with the new URD equal length headers. Has anyone had the JBA OR DT long tubes and then switched to URD? Worth the swap?
    Also, has anyone done a custom y pipe? I can't go fully catless in PA or I won't pass inspection, so I'm just curious to hear/see some custom y pipe jobs.
  2. May 31, 2016 at 4:33 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I went straight for the URD but youll have to decide if its worth the pain and suffering to install. They are awesome, but they took myself and 3 other mechanically inclined friends 7 hours to install. That being said i have the air injction and you dont, so you may suffer less.
  3. Jun 24, 2016 at 12:57 PM
    11_taco_DB
    11_taco_DB New Member
    Dalton
    2011 4x4 Tacoma
    Coldair exhaust programmer
    I bought the flowmaster American thunder exhaust (didn't care for it). I put a jones turbine on and it sounds way better maybe a little more power. I've been looking at dough thorely long tube headers with Y pipe for more power gain, bad or good idea?
  4. Jun 25, 2016 at 12:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Thorleys are good. URD Spec-U headers are even better.
  5. Jun 26, 2016 at 8:44 AM
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    Noticed that the URD header is listed at 595, but once you put it in the cart it bumps up to 670
  6. Jun 26, 2016 at 11:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Look closely. It says is light grey, " - Add Dual Rear O2 Simulator : Yes +$75.00"
    If you don't want those, then you will need to call. Be warned that you will have a CEL though.
    6xchamps likes this.
  7. Jun 26, 2016 at 11:39 AM
    6xchamps
    Fuquay Varina NC
    2015 AC
    ha. i was on my phone, but that clearly isn't an excuse. my reading comprehension was stuck at a.d.d.
  8. Jun 26, 2016 at 2:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. Jun 26, 2016 at 2:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There should at least be the option to deselect it. With a notice of information.
  10. Jun 26, 2016 at 2:33 PM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    As far as Y-pipes go is URD the best option?
    And how hard is it to install? @Torspd
  11. Jun 26, 2016 at 2:34 PM
    TacoJova
    Central Oregon
    I'm thinking of doing the Y- pipe first then if I'm not happy get the headers
  12. Jun 26, 2016 at 3:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes, they are the best option, and quality avaliable. Installation shouldn't take more than 30 minutes.
    WD-40 for the exhaust hangers. Copper antiseize for the threads of the O2 sensors, and hardware. I do not remember if gaskets come with the Y-pipe. The heavy duty ones from URD are multi-use, whereas the OEM header to Y are single use.
  13. Jun 26, 2016 at 3:40 PM
    TacoJova
    Central Oregon
    And you keep one set of cats right?
  14. Jun 26, 2016 at 3:42 PM
    TacoJova
    Central Oregon
    And how much difference in noise and performance does y pipe do?
  15. Jun 26, 2016 at 4:13 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Y pipe took me about half an hour, I wanna say it came with new gaskets. Noise will probably be a bit louder, but you'll notice alot more rasp at higher rpms since the back cats settle out engine noise. Performance you might see a slight bump, but if you're still on a stock headers and exhaust, you wont see much.
  16. Jun 26, 2016 at 4:18 PM
    TacoJova
    Central Oregon
    Well I've got a Borla and want more noise and if it's too much rasp I'll just add another muffler but I figure if I want more I'll just add headers
  17. Jun 26, 2016 at 4:25 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The equal length Y-pipe will net a little better gain than the 4x4 Y-pipe. If it fits your vehicle.
    We dyno'd my friends 4Runner after his Y-pipe install. Mid and up, it picked up a significant amount from before. Doug Thorley headers, and the rest stock until the swap.
    The dyno is is my Sig link.
  18. Jun 26, 2016 at 4:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes. In the oem headers.
  19. Jun 26, 2016 at 4:29 PM
    TacoJova
    Central Oregon
    I'm 4x4 so I don't think the equal length would work.
    BTW amazing build you got going
  20. Jun 26, 2016 at 5:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thank you.
