headers
Discussion in 'Performance and Tuning' started by Joeymgd78, Dec 30, 2011.
  1. Dec 30, 2011 at 1:04 AM
    Joeymgd78
    Joeymgd78 [OP] Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
    sorry for the stupid question. but what will changing your headers do for you?​
  2. Dec 30, 2011 at 1:12 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    nothing you would notice other then a different exhaust note,and exhaust breathing a little better.its not enough to actually feel the difference.:rolleyes:
  3. Dec 30, 2011 at 7:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Don't listen to that.
    They increase flow and scavenging of the exhaust pulses. Thus increasing efficiency of the flow, and improving hp and torque. A by product of that, is a change in exhaust note/tone.
    As long as you are referring to changing out to an upgraded header, over stock.
  4. Dec 30, 2011 at 9:21 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    ^agree with Torspd, when I installed my headers it opened my mid to top end nicely and when I tuned it, the benefit of less restrictions were easily realized.
  5. Dec 30, 2011 at 8:39 PM
    Joeymgd78
    Joey
    how hard are they to install it seems like it would be really easy
  6. Dec 30, 2011 at 8:44 PM
    Joeymgd78
    Joey
    yeah i already have a flowmaster 40 one int two out dual exhaust but i was seeing lots of rust on it before i deployed so its probably alomost time to do some work on it anyways
  7. Dec 30, 2011 at 8:45 PM
    Joeymgd78
    Joey
    anyone know a good place to order haeders that are good but not super expensive
  8. Dec 30, 2011 at 8:50 PM
    Tacos Por Vida
    Tacos Por Vida Well-Known Member
    Dominick
    Albuquerque, NM
    97 Taco
    3-inch revtek spacers 265/75 BFG AT Flowmaster exhaust K&N CAI 12'' Type R w/ 1000w amp pioneer cd deck tinted windows
    Check out urdusa.com. They run about $550-800
  9. Dec 30, 2011 at 9:00 PM
    jandrews
    '09 FourDubDee TRD OR
    You're not going to realize any meaningful changes without a tune.
    It will help your truck sound like a souped-up Civic though.
  10. Dec 31, 2011 at 4:30 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    The long tube headers make a very nice and very noticable improvement all by themselves.
    You will get a great gain with tuning, but tuning always improves things anyway.
    G
