Headers
Discussion in 'Performance and Tuning' started by kmrofka, May 1, 2009.
which one
  1. jba
    15 vote(s)
    65.2%
  2. gibson
    8 vote(s)
    34.8%
  1. May 1, 2009 at 1:24 PM
    kmrofka
    kmrofka [OP] Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    ok so i dont know which ones i want torn between
    JBA or GIBSON
    what do you guys think for those who have these... and whats the purpose of the ceramic plating
  2. May 1, 2009 at 1:45 PM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    I had a bronco back in 1994. I had JBA headers and Gibson exhaust. They are both a quality product. The inside of my Gibson muffler did rust out (I think a rock pin-holed it and muddy water got into it and rusted some of the insides - it rattled) but they sent a new one, no questions asked.
    I would probably go with the JBA headers.
  3. May 1, 2009 at 1:59 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    The ceramic coating helps them run cooler and helps protect from rust.
  4. May 1, 2009 at 2:17 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I have DT headers so I can't really contribute other than say I love them
  5. May 1, 2009 at 2:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be able to find a good deal on the TRD headers for your truck. They are a pretty good design.
  6. May 1, 2009 at 2:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for your truck.....im pretty sure the trd headers work out alot better/better gains, then jba,thorley or gibson. just to say.
  7. May 1, 2009 at 2:27 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    ok i will look into the trd ones as well
  8. May 1, 2009 at 3:24 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    ok i found trd headers for 469.75 should i pull the triger... i need to know the exiting diameter if anyone knows as well
  9. May 1, 2009 at 3:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its the same size as the OEM pipe. It should bolt right up. That price sounds a little high. See if you can find it cheaper. I have seen them under $400.00
  10. May 1, 2009 at 3:29 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    i know its the same size i wanted to know that size if anyone knows it.
  11. May 1, 2009 at 3:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2.25"
  12. May 1, 2009 at 3:40 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    ok now say i wanted to run straight headers and a drag muffler what am i going to lose have to remover and so forth
  13. May 1, 2009 at 4:06 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    come on chris spread your infinate knowledge upon me
  14. May 1, 2009 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im getting ready to head out with my Wife......Why do you want to run that set up? Your gonna loose a bunch of low end power, and probably not gain a thing on the top.
  15. May 1, 2009 at 5:12 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
    i just like the sound i dont know im debating now
  16. May 1, 2009 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Get the headers. Get the Dynomax Super Turbo muffler, and thank me latter. :)
  17. May 1, 2009 at 5:14 PM
    kmrofka
    Arizona
    03 V6 Prerunner SR5
  18. May 1, 2009 at 6:28 PM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    didn't take much persuasion haha
  19. Jul 14, 2009 at 4:49 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I just got thr TRD headers, and there is welding needed for the install. you have to weld a flange onto the cat.
    I cant wait to get them in!
  20. Sep 1, 2009 at 8:20 PM
    Wildtaco
    Wildtaco Active Member
    is the Dynomax Super Turbo muffler louder then the flowmaster 40 series??????
