Headgasket 2005 4.0 @ 330,000kms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EME, Jun 15, 2021.
  1. Jun 15, 2021 at 10:00 PM
    EME
    EME [OP] Well-Known Member
    Nick
    05 Tacoma sport
    looks like my gaskets are on the way out, been hearing the gurgle off and on for past year or so, now I can smell coolant on first start up. no over heating or coolant loss. I've had the truck almost 2yrs and put about 35,000kms on it.
    I'm planning on using parts from rock auto, how are ITM parts (part number 05395500) for timing chain stuff??
    Head gasket FEL-PROHS26330PT or VICTOR REINZ021078101 is either better?
    head bolts APEX AHB871
    I have not priced parts at Toyota yet,
    also I was thinking only of replacing timing chain stuff as a precaution, are they known to wear out around certain mileage? (like the old 22re was known to do?) or maybe they are fine??
    anyone have any bad or good opinions based on parts listed on use?
  2. Jun 15, 2021 at 10:32 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I would use only toyota parts for timing chains/guides/tensioners. Ive read horror stories about aftermarket part failures and having to pull everything back apart to replace. Definitely not something you want to go through
    4WDTrout likes this.
  3. Jun 16, 2021 at 4:51 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Do the timing chain and use all OEM parts.
  4. Jun 16, 2021 at 6:34 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Guaranteed at that mileage those timing chains have stretched to some degree, and it'd be silly not to replace them while you're in there and have it all tore down. Look at your knock sensors/harness too - it's a bitch to access and if the critters have even thought about nibbling on them, do it while you're in there.
    Aisin is the OE supplier to Toyota for the timing chains, gears, tensioners, guides, water pumps, fan clutches, etc. If you can't buy it from Aisin, buy it from Toyota. They lasted 330k KM, and you want it to go another 330k at least, right?
    For the gaskets, personally I splurged and bought the gasket kit from Toyota. Fel-Pro and Victor Reinz are the same gaskets usually, just in different packaging. Make sure you get the updated head gaskets, the old ones can still be bought! If you can't tell the difference by description alone, look up the head gasket kit for a 2007 or newer 1GR-FE and compare part numbers to a 03-05 1GR-FE.
    I've never used Apex brand hardware, but do replace the head bolts. IIRC, I used Mahle brand (but been using Mahle and Elring for decades now on Euro vehicles as they're both OE suppliers to the Swedish and Germans). It's a torque-to-yield bolt, so any quality/reputable brand should be just fine.
    EME[OP] likes this.
  5. Jun 20, 2021 at 7:25 AM
    EME
    Nick
    05 Tacoma sport
    called local dealership, normally 125(Canadian) my cost is 85$ each, waiting on email quote for the head bolts/timing components.... then its trying to find time to do it ( I own a small automotive shop) so to make a living, customers cars come first. Mechanics cars are usually last to get fixed.
  6. Jun 20, 2021 at 5:49 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    welcome to the rabbit hole entrance. ask me how i know. buy the best parts brother.
