Headlamps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silence9, Aug 22, 2014.
  1. Aug 22, 2014 at 4:24 PM
    Silence9
    Silence9 [OP] Solve et Coagula
    Alberta, Canada
    I'm ready to do the Blue light mod on my taco, I read the helpful sticky. But I was wondering if a person needs to take the whole headlight assembly out to change the lamps, or can you just unplug the harness and slide it out from behind? It's no fancy HID kit, just 6100k lamps.
  2. Aug 22, 2014 at 4:27 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Bulbs can be changed with out removing the headlamps.
  3. Aug 22, 2014 at 4:34 PM
    Silence9
    Alberta, Canada
    Thank you t4.
  4. Aug 22, 2014 at 4:40 PM
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    Bulbs are easy to remove. Headlamps required more work to remove. I tried removing my headlamp the other day and it appeared I have to drop my brush guard and front grille in order for me to remove it. Pain in the arss!
  5. Aug 22, 2014 at 4:45 PM
    Silence9
    Alberta, Canada
    Good to know. Thx!
    Whoever thought those clips that hold the lights in needs a karate chop to the throat. :mad: :crazy:
