Headlight adj after 2.5" and 1.5 aal
Discussion in 'Lighting' started by dirtrider262, Apr 13, 2013.
  1. Apr 13, 2013 at 7:55 PM
    dirtrider262
    dirtrider262 [OP] Member
    southern oregon
    2013 MGM TRD OR DCSB 4.0 6SPEED
    is there a way to measure or calculate to put my headlights back to stock ht
    so there not riding so hi after lift
  2. Apr 13, 2013 at 8:37 PM
    6spd
    6spd Well-Known Member
    san diego
    2012 4x4
    Check your local dmv law to set them to the legal height.
  3. Apr 13, 2013 at 8:52 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    This^
    Should be something like, the center of intensity should be 4" down at 25'.
    But check first.
  4. Apr 13, 2013 at 9:21 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    0 double cab taco
    just do this.
    1. Find a level surface and a vertical wall or garage door. Park the vehicle close to the wall and, using the masking tape, mark the low-beams' horizontal centerlines.
    2. Mark the vertical centerlines of each beam and the center of the vehicle with masking tape. Marking the vehicle centerline is helpful to determine side to-side alignment, or lack thereof.
    3. Move the vehicle 25 feet straight backwards. Turn the horizontal-vertical adjusting screws to position the low beam hot spots two inches below and to the right of the taped centerlines.
  5. Apr 15, 2013 at 5:58 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    That's all you need to do.
