Headlight adj. screw
Discussion in '1st Gen. Tacomas (1995-2004)' started by I-Town-Budman, Jan 14, 2020.
  1. Jan 14, 2020 at 6:44 PM
    I-Town-Budman
    I-Town-Budman [OP] Member
    The 45638
    2001 Red Tacoma Dual cab TRD
    Nuttin yet?
    Has anybody, other than this idiot, ever stripped the end of their headlight adjustment bolt,screw, off? If so what did you do? Can it be replaced? Thanks in advance if anybody has a remedy.
  2. Jan 14, 2020 at 8:21 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I tried adjusting my brand new TYC headlights and it wouldn't turn - just stripped. Luckily they were aimed properly from the factory so I just left it.
    Unfortunately I don't know the answer to your second or third questions.
    I-Town-Budman[OP] likes this.
  3. Jan 14, 2020 at 8:55 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    The hex end is smaller diameter than the bolt. You could regrind the hex flats again. That bolt sticks out a bit so there is probably room. And yes if you take it apart that bolt pops out of the socket. Could replace from junkyard or Amazon, Totota will kindly sell you a whole new light assembly.
    The whole unit pops out with a couple 10mm bolts, easy to fix. You have to take the front grill off to get to the 10mm bolts
  4. Jan 14, 2020 at 9:14 PM
    I-Town-Budman
    The 45638
    Nuttin yet?
    I was sort of figuring that they could somehow be replaced but just thought I'd check on here just to make sure before I started taking the grill off and taking everything apart to see. Thanks for the info Brother!!
    tacoma_ca likes this.
