Headlight Adjustment Bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ken08Taco, Mar 12, 2016.
  1. Mar 12, 2016 at 5:26 PM
    Ken08Taco
    Ken08Taco [OP] Well-Known Member
    Ken
    Pittsburgh, Pa.
    2008 Tacoma TRD Sport
    Anyone have any tips on the best type of wrench to use on the headlight adjustment bolts on my 2008 Tacoma? I put on new assemblies today and was having a helluva time with the wrenches I have getting the heads to stay on the bolt heads!
    Those lower adjustment bolts are a real PITA to access.
  2. Mar 12, 2016 at 5:32 PM
    -Razr-
    -Razr- Active Member
    CJ
    '03 DC Prerunner
    try sticking a ratchet in there
  3. Mar 12, 2016 at 5:32 PM
    jnmargarit
    jnmargarit Well-Known Member
    Vancouver, B.C.
    '14 TRD Sport
    I used a #3 Phillips. It fits perfectly in the gear teeth
  4. Mar 12, 2016 at 5:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You should be using a screwdriver not a wrench...
    jnmargarit likes this.
  5. Mar 12, 2016 at 7:33 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Yep, Phillips screwdriver. I made the same mistake.
  6. Mar 12, 2016 at 7:36 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
  7. Feb 21, 2018 at 2:27 PM
    Scotsman
    Scotsman Member
    This is where I'm getting confused, is it clockwise on the screw, or clockwise on the screwdriver? Sorry guys and thanks for all help
  8. Feb 21, 2018 at 2:31 PM
    Pigpen
    Dan
    Northwest Montana
    Screwdriver
  9. Feb 21, 2018 at 2:33 PM
    Pigpen
    Dan
    Northwest Montana
    Mine need to come down a few turns. @MuddyJackson 's need to come down quite a bit. It warmed up to 12 degrees F. Now's the time to do it.
  10. Feb 21, 2018 at 2:38 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Ratchet, adjust with the lights aimed against a wall. If you want to go the other way, just switch the ratchet. That’s how I did it at least.
  11. Feb 21, 2018 at 2:40 PM
    Pigpen
    Dan
    Northwest Montana
    I use a screwdriver and just count my turns.
