Headlight adjustment, How to?? 05 Taco
Discussion in 'Technical Chat' started by CBRN, Jan 21, 2009.
  1. Jan 21, 2009 at 5:38 AM
    CBRN
    CBRN [OP] Member
    Joe
    Fort Hood, TX
    Taco SR5 PreRunner
    Hello everybody, can someone please tell me how to adjust my headlights on my 05 Tacoma, I just put a 3" leveling kit and I need to lower the beam.
    Thanks, Joe
  2. Jan 21, 2009 at 5:43 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  3. Jan 21, 2009 at 5:46 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    there is a large (maybe 12mm) bolt head on the rear of the light housing towards the bottom. If you look at the inner lens while turning the bolt you will be able to see if it is going up or down. I would suggest trying to do 1/4 turns and counting them so you know where factory setting was, just as a place keeper.
  4. Jan 21, 2009 at 6:43 AM
    fasn8dave
    fasn8dave Hey guys watch THIS!
    Lewisville, NC
    06 DC 4x4
    3" Suspension Lift Custom Wheels 265 / 75 / 16 Nitto Terra Grappler Tires (32") Hard Bed Cover Front Bull Bar / Skid Plate Tinted Glass Header Mount GPS Billet Grille
    Yeah I think I used a socket set to do mine. Make sure you face a wall with the lights on so you can make sure they're both at the same height...
  5. Jan 21, 2009 at 7:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A long phillips head screw driver fits into a channel and adjusts the light also. If you can reach the bolt head with a socket.
  6. Feb 8, 2018 at 7:32 AM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    This old thread is the top result from a Google search. Since all of the links no longer work, here's the fix:
