Headlight Adjustment Screw
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyinn, Jul 7, 2008.
  1. Jul 7, 2008 at 11:39 PM
    flyinn
    flyinn [OP] Active Member
    P-Town
    09' Tacoma 4X4 TRD off Road
    Magnaflow exhaust
    My headlights were off a bit on my 09 taco. I found the adjustment screw, but there is another, and I could not tell what it was adjusting. The screw under the hood low and closer to the fender controls the pitch, but what does the one do w/ the cover closer to the top of the light? Anyone know?
  2. Jul 8, 2008 at 4:15 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    one controls up and down movement....the other controls left to right movement i do believe
  3. Jul 8, 2008 at 8:48 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Open hood, there are two adjustment aiming screws on the back side of the headlamps. The lower one (slightly harder to get to) is the up/down one. Looking straight down at it, you can see an opening where you slip a philips head screwdriver in there and turn to make the adjustment. Sorry can't remember which direction I turned it. Think turning screwdriver clockwise aims up, counterclockwise down. Per manual, make sure the last click is made clockwise (ie if you need 2 clicks counterclockwise, make 3 then 1 back to make 2)
    I marked with a marker on the screw my orginal starting point. I did in front of white wall to ensure direction. Better yet, have a buddy look while you change to be sure of your direction. Mine only needed two clicks after the heavier leaf spring TSB went in (raised the rear up). So dont overdo it. good luck.
  4. Nov 11, 2009 at 8:38 PM
    twillard
    twillard New Member
    Todd
    Phoenix
    10 TRD access cab
    2.5" Daystar blocks front, Toytech add a leaf rear- 2".
    Thanks much for directions on adjustment. Really need to do so after a lift.
  5. Nov 11, 2009 at 9:00 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Here is the PDF w/diagrams and info ^^^^^^^^^^^^^^^
  6. Nov 11, 2009 at 9:44 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    thats a breather...
  7. Nov 15, 2009 at 7:42 PM
    twillard
    twillard New Member
    Todd
    Phoenix
    10 TRD access cab
    Thanks much for the directions.
